3D SketchUp of the "Under-the-Mark V" Accessory Cabinet
JohnHoeger
Re: 3D SketchUp of the "Under-the-Mark V" Accessory Cabinet
Post by JohnHoeger »
Thank you Az,
You nudged me into becoming acquainted with SketchUp. It is intended for 3D drawings but I used it here for 2D drafting.
Top_Shelf_v2.pdf
Top Main Shelf Detail
(16.76 KiB) Downloaded 1838 times
These are simple shapes but it worked better than I had expected. The automatic dimensioning works well and made it easy to line up and space out locations. The tape measure was also very handy. I worked around its limitations in adding text by exporting the drawing in .pdf format and using PDFescape to add the titles.
Didn't see a way to make dashed or dotted lines but I suppose you can always use colored lines for those purposes.
Thanks again,
~John H in San Bernardino
Asbrand
Post by Asbrand »
Glad it helped! Sketchup is an amazing program for free!
-Az
damagi
Post by damagi »
Now...perhaps a v3 specially designed to accommodate the lift assist ;) Anyone?
Asbrand
Post by Asbrand »
LOL - feel free! *grin*
-Az
videobear
Post by videobear »
damagi wrote:Now...perhaps a v3 specially designed to accommodate the lift assist ;) Anyone?
I have the lift assist, and after I installed it, I realized that it pretty much precludes any such cabinet hung from the bench tubes. If someone does come up with a design that'll work with it, it would be super.
damagi
Post by damagi »
http://shopsmith.com/ss_forum/beginning ... ml#p194843
larryhrockisland
Post by larryhrockisland »
Here's what I did back in 2008. Hopefully there are pictures(first time to try attachments) Still in service today. It has aged better than me :rolleyes:
Larry Hargrove
Rock Island, Ok
1957 Mark V 500 (350389)
1953 10ER
Another 10ER
Bandsaw 2012 Jointer 2012
camerio
Location: Valcartier, just north of Quebec City, CANADA
Post by camerio »
Wow .... like your version Larry.
larryhrockisland
Thanks. I keep the universal lathe tool rest in the bottom left drawer and with the jointer on the back everything is rock solid, maybe too much so when retracting the casters. Pretty heavy kerthunk when it lands. I do have the premium casters now so it is still easy to roll around.
Larry Hargrove
Rock Island, Ok
1953 10ER
Another 10ER
t3steve
Post by t3steve »
Asbrand,
How do I view the cut sheet?
