Yeah, I was going to get the starter kit from PS but I can't afford it now. I was going to get the parts individually as I can. Woodcraft has the #1 and
#2MT mandrels.
Turning Pens
- RobertTaylor
woodcraft also has a replacement shaft for their mandrels that will work in the shopsmith drill chuck or 1/4" router chuck. it is about $3.00. fwiw a 7mm mandrel is not 7mm. the tubes measure 7mm od. the mandrel fits inside the 7mm tube and is 1/4" diameter.
- wlhayesmfs
Just buy the replacemnent shaft 141502 from Woodcraft for just $2.99 and put it in the jacob's chuck. That was what I started with. Cheap and easy start. Then you buy the pen sleeves you need for the kit you build.You can even got the curl nut for the of the shaft for a dollar or two.
Good luck I find once you can find what nice pens or other kits you can turn from just any piece or scrap of wood you can find you won't stop.
Bill
Broken Arrow OK
Broken Arrow OK
Would these work for pens or are they too small? http://www.amazon.com/8-pc-Mini-Wood-Ca ... &qid=12521
Mark V 520, Ryobi 12" mitersaw, Delta 10" tablesaw, DC 3300.
navycop
JMHO - I don't think I would try to use those chisels for pen turning. They are designed to do carving and I suspect that they would probably cause the tool to catch the pen blank either ruining it or worse and possibly causing injury to yourself. They are designed to take out different portions of wood depending on which type of effect you are trying for. I think the skew is pretty much all you need for turning pens especially if you are starting with a round blank. I use a gouge for a square blank then finish with a skew and I personally prefer the larger tools compared to the smaller pen turning tools.
Ron from Lewisburg, TN
Rkh2 is correct. Those won’t work on the lathe. You need something like this.
http://cgi.ebay.com/SHOPSMITH-SHOPMATE- ... 286.c0.m14
