Turning Pens
Turning Pens
Can you use the same turning tools for pen turning that the basic turning comes with or smaller tools needed?
- Ed in Tampa
Yes you can as I have done it. However as you gain more experience and want to try different things you may want to buy some smaller tools.dasazer wrote:Can you use the same turning tools for pen turning that the basic turning comes with or smaller tools needed?
But to try it to see if you like it, yes your basic SS turning tools will work fine.
Make some sawdust
Pen turning
I agree with Ed that you can easily turn pens with the standard chisel set. Give it a try and see. The minature set is the better of the smaller chisel sets as it gives you greater flexibility with the 5 tools vs the 3-tool pen turning chisel kit.
The slim line pens are the easiest to start out with and there are plenty of suppliers for the kits. I would try woodturningz.com for pen kits as their prices and delivery are as good as it gets. Good luck and enjoy the trial as you will find it very rewarding. Make great gifts and can use some othat scrap wood lying around the shop.
Spike:
Spike:
Life is a chip at a time,
Spike13
Spike13
Turning Pens
Just ordered the beginner kit for chuck (needed for SS) from Craft Supplies and a Live Center Cup from SS. I think that should get me started. Any other suggestions.
Pen turning
Dasazer!
Good for you! If you got the mandrel and the live center, you're on the way to turning pens.
You can also use the 1/4" router chuck, SS item #514632to put the mandrel in permanently, rather than put it in the jacob's style chuck. Gives you more room for clearances with the tool rest. You may also want to look at the 4" tool rest if you are going to do any lipstick pens. Allows for getting the tool rest closer to your work, not so big a gap between the tool rest and the turning, improves support.
Don't forget to re-grind your lathe chisels as the 5 degree angle on the chisels (standard grind for all chisels) should be opened up to 11-13 degree for better shearing and improved clearances.
Have fun with the pens.
One chip at a time!!!
Spike13
Spike13
Get the Mini Set
I totally agree with Spike13. Yes, you can turn with the large basic set, but as you gain experience in turning, you will see/learn the need for the mini set which will allow you to create more detail, more easily, in your pen turning. Besides, you will find more uses for the mini set as it opens the door for such things as Chess pieces, small wood parts, etc. Also, Check out, and obtain a catalog from PennState.com which will give you a lot of information, and will display all kinds of items that you can turn.
Good luck!
FlashbacPT
Good luck!
FlashbacPT
pens
I agree the slimline are easiest to learn with I recently found a German bit that drills the 7 mm hole cleaner that any others I have tried they are called colt bits work great drills the plastic blanks witout melting it to the bit cler the chips faster so not alot of chance to break the blank as i have been able to do with other bits
