Definitely green on mine, you needed to let the program run an automatic color set.ERLover wrote:Same thing on mine Dusty, grayer.dusty wrote:I have had very little exposure to any Greenie (except in pictures) but that does not look like any Shopsmith green that I have seen. But then there is yours. On my computer, your tie bar appears to be more of a gray than a green.
spray paint match for repainting a "greenie"
Re: spray paint match for repainting a "greenie"
What 'program'? How does it 'see' the screen?jjbuzard wrote:Definitely green on mine, you needed to let the program run an automatic color set.ERLover wrote:Same thing on mine Dusty, grayer.dusty wrote:I have had very little exposure to any Greenie (except in pictures) but that does not look like any Shopsmith green that I have seen. But then there is yours. On my computer, your tie bar appears to be more of a gray than a green.
I have to ask. How did you break the tie bar during installation?
What 'program'? How does it 'see' the screen?[/quote]
Your monitor set up disc or program for your monitor that you can down liad, has a color set up program that can calibrate your color, so you see colors more ccurate, other than that there is a piece of hardware "Spider" that hooks up usually by USB and it sets your color settings, you don't need yhay, it is expensive, let your monitor calibrate it.
Did something stupid, it hung up so I gave it a couple of wacks with a rubber mallet....SNAP!jsburger wrote:I have to ask. How did you break the tie bar during installation?![]()
The guy I bought it from said he has broken 2 trying to get them off.
jjbuzard wrote:Did something stupid, it hung up so I gave it a couple of wacks with a rubber mallet....SNAP!jsburger wrote:I have to ask. How did you break the tie bar during installation?![]()
Gentle Persuasion applied at the proper location.
Never on the center web.
They can get cocked.
A Mark VII is fun.
OK, I see. I was putting a 10ER speed changer together the other day and got the movable arm cocked on the main casting. I had one heck of a time getting it apart. Fortunately I didn't break anything.jjbuzard wrote:Did something stupid, it hung up so I gave it a couple of wacks with a rubber mallet....SNAP!jsburger wrote:I have to ask. How did you break the tie bar during installation?![]()
