iaokie requesting help
iaokie
Rack Removed
Post by iaokie »
Got the track I mean RACK[ATTACH]14128[/ATTACH]
[ATTACH]14129[/ATTACH]
[ATTACH]14130[/ATTACH]
[ATTACH]14131[/ATTACH]
[ATTACH]14132[/ATTACH] removed
Could not drill out because pin is stainless and rivet is aluminum so used a small brad and easily punched the pin through the rivet then using a screw driver and putty knife carefully pried the rack off
Finished polishing the last tube :D
camerio
Location: Valcartier, just north of Quebec City, CANADA
Post by camerio »
WOW ! Amazing job !
We are so lucky that you gave us a chance to be witness to that kind of restoration.
When I say "amazing job", I mean as much the polishing but also the illustration of it on this forum.
Posts like this one and many others are the reason we keep coming back to this forum.
Thank you and keep up the good work.
Camerio
MarkV 520 & Band saw
iaokie
Finally time to reassemble
Post by iaokie »
Still have more polishing to do but getting impatient so started to reassemble
Another visitor by the shop :eek:
Don't think I need her help :D [ATTACH]14144[/ATTACH]
[ATTACH]14145[/ATTACH]
iaokie wrote:Still have more polishing to do but getting impatient so started to reassemble
She must have been attracted by all that black stuff you are assembling!:rolleyes:
iaokie
Belts for Mark VII
Post by iaokie »
Anyone have a good source for the drive and Poly V belts for the Mark VII
I've seen some new on E-Bay for about $45
Don't know where they're made or how good of quality they will be :confused:
billmayo
Post by billmayo »
iaokie wrote:Anyone have a good source for the drive and Poly V belts for the Mark VII
Buy from Shopsmith when the belts are in stock. When Shopsmith has them on back order, I have received quick excellant service and parts from tristateauto (Ebay). Tech help is available for ALL purchases. Call 908-241-2885 7 days. They also carry the Gilmer Drive belts along with the Poly-V and Motor Drive belts along with many new Shopsmith parts. I have been using their belts and parts with excellant results.
iaokie
Post by iaokie »
Thanks Bill
BTW that 10 ER in Catoosa droped to$185
Hmmmm !!!!:confused:
Tempting
jayp413
Post by jayp413 »
If they are the same as the Mark V belts I have a spare used set you can have if you pay for shipping :)
jayp413 wrote:If they are the same as the Mark V belts I have a spare used set you can have if you pay for shipping :)
With 4 SS, I would suggest keeping a set(or do you already have more than one spare 'set')?:D
iaokie
Post by iaokie »
Absolutely Yes :D
I'll PM U about some other things i need to purchase
maybe we can work something out
Thanks Jim
