caster system for large lathes
Craft Supplies is advertising a new caster system for large lathes called the Lift, Lock, and Roll. The price is $299. Sure makes the Shopsmith casters seem inexpensive in comparison.
http://www.woodturnerscatalog.com/store ... nerid=e260
Gary
Gary
bobgroh
A serious lathe should NOT be on wheels. You want total stability. If I have a big hunk of wood on there, I do not want anything on that lathe to be jiggling around, vibrating, etc. Just my opinion. Yeah, it makes moving one a bit of PITA. Life is compromises.
Bob Groh
SS SPT's: Bandsaw
SS SPT's: Bandsaw
You did look at the link right?bobgroh wrote:A serious lathe should NOT be on wheels. You want total stability. If I have a big hunk of wood on there, I do not want anything on that lathe to be jiggling around, vibrating, etc. Just my opinion. Yeah, it makes moving one a bit of PITA. Life is compromises.
pennview wrote:I agree with Bob. No casters on a heavy lathe. In fact, the lathe should be leveled and anchored to a concrete floor.
It looks to work just like the SS castors. Wheels down ya move, wheels up and the lathe legs set on the floor.
- terrydowning
A powermatic 3520 weighs in at 630 pounds! I would not trust the stock SS casters with that much weight!
Of course if I were to purchase a powermatic 3520. It would be leveled and secured to the floor as I would be turning rather large pieces of wood on a regular basis and would prize stability and the improved accuracy that comes with it.
This is another Apples to Oranges comparison. You can not reasonably compare the SS mark5/7 lathe capability to a powermatic 3520. They are in entirely different leagues. While you can make a pen with both, turn 34" spindles on both and even turn 16" platters on both. I would not turn 16" platters on a SS lathe day in and day out with out modifications. The powermatic is designed for that kind of heavy lifting in a lathe. While the SS lathe is designed more for casual/light usage.
Can we please stop trying to compare the SS multi-function tool designed for the home hobbyist to Industrial Grade tools? They do not compare. Don't get me wrong, I love my '55 and would not part with it. But having danced with just a 10" piece of bowl blank, I can't imagine spinning 16" without a speed reducer, and a lot of weight tacked on. I would do it without hesitation on a powermatic 3520 though.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
Now WHY wood ya use the SS castors on a powermatic?terrydowning wrote:A powermatic 3520 weighs in at 630 pounds! I would not trust the stock SS casters with that much weight!
