In my Mark V restoration I'm considering nickel plating the dials knobs etc.
Any tips, comments pros, cons, do's, dont's... should I just forget it?
I prefer cheap easy instead of expensive kits.
I would prefer buying nickel sulfate and a Nickel anode over expensive kits.
But good results is my priority.
Is it better to copper plate first?
Yes I will experiment on scrap aluminum castings first.
Any photos here of others results?
Let me add my other thought... polish the #@%$ out of them and clear coat them
Nickel plating
I'd be curious what nickel plating would cost, but just out of curiosity.
You can get some great results from just polishing. Check out this thread: http://shopsmith.net/forums/showthread.htm?t=3078. The first post has an index, organized by topic, linking to other posts in the thread. Check out the links regarding polishing.
Heath
Central Louisiana
Central Louisiana
I've found these on youtube it's what got me thinking.
http://www.youtube.com/watch?NR=1&featu ... VkFMJeotcg
http://www.youtube.com/watch?NR=1&featu ... cz8Py7bjzQ
http://www.youtube.com/watch?feature=fv ... dsl-JHb9Tg
The expensive kit stuff
http://www.youtube.com/watch?v=CMZNVApY ... re=related
I have found different places that use other chemicals .... I don't know much about chemistry..
- terrydowning
I polished my aluminum handles with tripoli and white diamond. I think they turned out good enough for me.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
lightnin wrote:Yea, why I'm thinking plating or clear coating is to stop oxidation in the future.
So whatever I end up doing, it will start with the best polish job I can do.
And thanks because I have never polished aluminum before and am not sure
exactly what is the best way.
Do some reading here for polishing aluminum.
http://www.shopsmith.net/forums/showthr ... h+aluminum
