Jointech system
- camerio
- Location: Valcartier, just north of Quebec City, CANADA
Jointech system
What about the Shopsmith profence rails Ed, did they come with that Jointech system you were telling me about ?
Camerio
MarkV 520 & Band saw
The front rail - main table is 518488 (changed to 522371)
The front rail - extension/floating table is 518489 (changed to 522367)
The rear rail - main table is 518490
The rear rail - extension/floating table is 518491
Side Note: I did have trouble finding these numbers and ultimately had to rely on my own documentation because I could not find them on Shopsmith.com.
The descriptions for both of the front rails are nondescript and NEED ATTENTION.
I got to thinking about this and subsequently confused myself. What changes have occurred to the front rails that would necessitate a part number change? The original numbers sited above came from documentation I received with my 520 upgrade kit. These main table rails have the magnetic strip.dusty wrote:The front rail - main table is 518488 (changed to 522371)
So the question is: How do the 522371 and 522367 numbers differ?
I do miss the Product Change Bulletins that I had to review every week when I worked for a defense contractor. They would answer that question.
I would guess that the front rail change was the direct read scale change. I would imagine the old number is without the magnetic part, while the new part number has it.dusty wrote:I got to thinking about this and subsequently confused myself. What changes have occurred to the front rails that would necessitate a part number change? The original numbers sited above came from documentation I received with my 520 upgrade kit. These main table rails have the magnetic strip.
damagi AT gmail DOT com
damagi wrote:I would guess that the front rail change was the direct read scale change. I would imagine the old number is without the magnetic part, while the new part number has it.
That might be a logical guess but that is not the case.
In my post, the original numbers are for the parts that I have which are for rails that support the direct read scale. My rails have magnetic strips.
The "changed to" numbers are what pops up if you perform a part number search for the original numbers on shopsmith.com right now.
SKU #'s changes could be from VENDOR changes?dusty wrote:What changes have occurred to the front rails that would necessitate a part number change?
