Suspect MarkV Switch. Can I...?
guitarnut
Post by guitarnut »
Place jumpers on the motor wires and bypass the switch to eliminate it as a problem?
I have a MarkV C gen headstock. This thing has been bullet proof for years with regular oiling and cleaning. This morning I set up my band saw and hit the power switch but nothing. The switch has been acting odd lately...sort of soft throw instead of a firm click. So, I removed the switch, blew it out, checked it with a meter and all is fine. I reinstalled it and still nothing. The motor and all internals are free...nothing stuck. No motor hum...just silence.
Anything else I should check?
Mark
SW Indiana
Mark V 500, SS Band Saw, SS Jointer, Ridgid 13" planer, Ridgid Belt/Drum Sander, Delta 50-720 dust collector.
"Thought that is no longer limited brings experience that is no longer limited" - Marianne Williamson
rjn2649
Post by rjn2649 »
In your post you kinda skip over some of the basic things, maybe you did them and didn't post...
SO....
Power from the outlet? breaker, or fuse?
Is the cord in good shape? Check it for continuty...unpluged of course.
I just state this because I've done service calls, ASKED if the client checked the breakers, and walked up and found a breaker triped...
AND even worse, I just did somethng similar the other day:o
guitarnut
Post by guitarnut »
rjn2649 wrote:In your post you kinda skip over some of the basic things, maybe you did them and didn't post...
SO....
Thanks. No problem with asking. I have verified all of the above.
I metered the power cord and got an open reading on all pins with the switch off. Same with the switch on.
I made two 12 AWG jumpers and put them in place. This time I get 0 ohms between the neutral and hot. So, it looks like I have a bad switch.
Any issue with using jumpers to verify all else is working?
Mark
SW Indiana
guitarnut wrote:Thanks. No problem with asking. I have verified all of the above.
As a test, yes.
As a modus operandi, maybe.
Safety features of the switch will be missing?
Turning on/off will require inserting/pulling out the plug. Two hands may be required.
Caution required!!!;)
As a permanent solution, NO!!!
guitarnut
Post by guitarnut »
JPG40504 wrote:As a permanent solution, NO!!!
Thanks, JPG.
I tested with the jumpers. Everything is fine. I ran the band saw and drill press most of the afternoon. Bit of a pain having to use the plug but I finished what I needed to finish for the day.
New switch on the way. I wouldn't even consider the jumpers as a permanent solution. A bandaid at best. ;)
Mark
SW Indiana
