I recently purchased a used 6" Shopsmith belt sander. I do not know its age, but the color side housing pieces is the more recent grey (but it has the smaller dust port). I plan to take it apart for cleaning, and I am considering sanding and painting the side housing pieces, which are dinged up. I have a can of the Shopsmith grey spray paint. Are the side pieces powder coated, and if so, will the spray paint bond properly?
I did not receive with my purchase the Instruction Manual (and parts list). This 2006 thread indicates that I will need to purchase the manual from Shopsmith; is that still the case?
Thanks for your help.
Hank
Belt sander
Belt Sander
Yes you can purchase the manual from SS and I think the cost is $9.95 + shipping.
Go to http://www.shopsmithacademy.com/SS_Arch ... Tuneup.htm to watch the Sawdust Session on servicing your best sander.
Brian
Mark V-500 Purchased New In 1980, SS Bandsaw (free), SS Jointer, SS 6x48 Belt Sander (free), SS Storage Station (free), Powermatic 64A Table Saw, Powermatic 1140F Drill Press, Delta 46-460 Midi-Lathe, Delta Scrollsaw, Bosch 12" Dual Compound Miter Saw, MLCS Router Table w/Bosch Router, Penn State dust collector.
Thanks, S Brian. I placed an order with Shopsmith for the Manual.S Brian wrote:Yes you can purchase the manual from SS and I think the cost is $9.95 + shipping.
Any advice, anyone, about the spray paint?
Hank
- terrydowning
At least no more so than any other paint.SDSSmith wrote:I do not believe you will have a problem with the paint adhering to the original paint.
Good prep dictates you should clean and scuff old paint with sandpaper.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
You can also find a lot of information about the belt sander and it's capabilities here:
http://www.shopsmith.com/academy/beltsand/index.htm
Abraham Lincoln
Abraham Lincoln
