Mark V switch
Mark V switch
While checking a problem on my power stock the wiring became dislodged from the switch. I have a white and blue with same female ends and a blk and white with the same type ends. I ckd my manuals and can't find which go where any suggestions. I do have photos, but I'm new and don't know if they can be attached. Any help would be appreciated.
wrmnfzy wrote:While checking a problem on my power stock the wiring became dislodged from the switch. I have a white and blue with same female ends and a blk and white with the same type ends. I ckd my manuals and can't find which go where any suggestions. I do have photos, but I'm new and don't know if they can be attached. Any help would be appreciated.
They slipped off, and will slip back on.
a white on each terminal on one side.
A black at one terminal on the other side, and a blue on the remaining terminal on that other side.
Mark V switch
Thanks, it worked.
- robinson46176
wrmnfzy wrote:Thanks, it worked.
Now take an "after" picture and drop it in your Shopsmith file.
