Bandsaw blade
Bandsaw blade
Out of necessity, I had to buy a bandsaw blade for my 11" shopsmith bandsaw from a local hardware vendor. At the time I wasn't sure of the length of the blade. So I bought a 72 1/2" blade that is 1/2" wide with 3tpi. After I got home I reviewed the manual that came with my bandsaw and discovered that the blade should be 72". My question is ...will the 72 1/2" blade fit the saw if I adjust the tensioning screw to make the blade fit securely? There seems to be quite a bit of adjustment in the tensioning screw.
San Diego
San Diego
If you have the manual check the limits of bandsaw blade size. You can put the blade on the machine and then adjust the blade tension with the tension scale. If you do not get any interference it should be OK. However the top wheel will probably be very close to the top of the casting but should NOT rub on the casting.
Shopsmith specifies the blade be 72" +/- 1/2" in length. You should be fine with that blade. If not, I am sure there is someone local who can help you out.rdewinter wrote:Out of necessity, I had to buy a bandsaw blade for my 11" shopsmith bandsaw from a local hardware vendor. At the time I wasn't sure of the length of the blade. So I bought a 72 1/2" blade that is 1/2" wide with 3tpi. After I got home I reviewed the manual that came with my bandsaw and discovered that the blade should be 72". My question is ...will the 72 1/2" blade fit the saw if I adjust the tensioning screw to make the blade fit securely? There seems to be quite a bit of adjustment in the tensioning screw.
Rob in San Diego
SDSSmith wrote:Shopsmith specifies the blade be 72" +/- 1/2" in length. You should be fine with that blade. If not, I am sure there is someone local who can help you out.
The upper length limit would be the arm/wheel interfering. Same for the lower limit. Ends of tension adjusting screw also.
If it can be tensioned properly and tracks correctly, 'it fits'!:)
Now THAT is a mystery!!!:DSDSSmith wrote:Shopsmith specifies the blade be 72" +/- 1/2" in length. You should be fine with that blade. If not, I am sure there is someone local who can help you out.
