Storage Question
- Ed in Tampa
Storage Question
How do you store your SS sanding disks and conical sanding disk?
How do you store the actual sand paper sheets.
I just tore down my SS cabinet. Long story but let me say I prevented what could have been a tragedy.
In any case I need to rebuild something.
Enclosed cabinet to keep the dust and prying eyes out.
I want to store my upper and lower saw guards, my fence, some saw blades and three sanding disks. Along with my 510 fence that is now a router fence and a few other things.
Every good idea I come up blows up when I consider my sanding disks.
So how do you store yours? Also any tells of saw blade and fence storage might give me another idea.
Thanks guys looking forward to your ideas.
Ed in Tampa
Stay out of trouble!
Blade and Sanding Disk Storage
I need to rebuild mine to facilitate additional blades and sanding disks but this is what I have.
[ATTACH]17406[/ATTACH]
[ATTACH]17407[/ATTACH]
[ATTACH]17408[/ATTACH]
[ATTACH]17409[/ATTACH]
The racks are not identical.
You can also see that I need to do some work on hose and sanding belt storage.
- Blade Storage 001 (Custom).JPG (78.04 KiB) Viewed 2267 times
- Blade Storage 002 (Custom).JPG (87.47 KiB) Viewed 2302 times
- Blade Storage 003 (Custom).JPG (86.76 KiB) Viewed 2269 times
- Blade Storage 004 (Custom).JPG (81.01 KiB) Viewed 2273 times
I keep mine all in one cabinet. Not fancy - still all plywood. It is the top cabinet of the "Shopsmith" that that came with my MARK V. In the photo from left to right - on the lower level: conical disk, flat sanding disk, box containing biscuit cutter, lower saw guard holding a blade, dado blade, saw blade with sanding disks in envelopes behind, saw blade, saw blade.
Lots of misc. items hung on hooks above the fore mentioned.
[ATTACH]17410[/ATTACH]
- cabinet_inside.jpg (125.66 KiB) Viewed 2228 times
- robinson46176
dusty wrote:I need to rebuild mine to facilitate additional blades and sanding disks but this is what I have.
I "really" like those Dusty. Simple and elegant...
My hoses are hanging over an 8" round furnace duct so far.
Is your shop built with burnt adobe block?
Thanks, Francis.robinson46176 wrote:I "really" like those Dusty. Simple and elegant...![]()
My hoses are hanging over an 8" round furnace duct so far.![]()
No burnt adobe. Simple slump block but heavily insulated.
- Ed in Tampa
Do your holders get much dust in them?
Chuck I like your Cabinet but space constraints make the thick storage doors impractical. If I lowered the cabinet I would get around the problem so yes it might work.
Anybody have any unigue sanding disk storage ideas inside cabinets?
My problem is dust, rust and insects. Any thing left exposed to inside of my garage (shop but I keep both cars in over night) is subjected to dust from woodworking but also from the cars coming in. Exposed to moisture high humidity in Florida plus car coming in out of rain with hot engines that make more steam. And insects, I can and often do brush down spider webs every day. If the metal is exposed to open garage the spiders seem to love to crap on it. If the crap is not removed fairly quickly within a month it will stain the metal. Some of my saw blades/sanding disks aren't used but once every 6-9 months. They would be destroyed unless I wiped them down every month or so.
Right now I control the dust and humidity and insect problems with lots of Johnstons Paste wax and keeping everything in the closed cabinets or with covers thrown over them.
Come on guys I know some of you have some great ideas on storage for SS sanding disks and saw blades.
Ed in Tampa
Ideas? yes. Great ideas? you decideEd in Tampa wrote: Come on guys I know some of you have some great ideas on storage for SS sanding disks and saw blades.
http://www.shopsmith.net/forums/attachm ... 1193969085
Chris
Good luck with the critters. I fight an ongoing critter battle here too. I have beaten the pack rats back. Now I am having trouble with quail who want to nest on my shelves in the shade.Ed in Tampa wrote:Dusty
Do your holders get much dust in them? Yes, Ed. Some of it is sawdust and some of it is desert dust.
My problem is dust, rust and insects. Any thing left exposed to inside of my garage (shop but I keep both cars in over night) is subjected to dust from woodworking but also from the cars coming in. Exposed to moisture high humidity in Florida plus car coming in out of rain with hot engines that make more steam. And insects, I can and often do brush down spider webs every day. If the metal is exposed to open garage the spiders seem to love to crap on it. If the crap is not removed fairly quickly within a month it will stain the metal. Some of my saw blades/sanding disks aren't used but once every 6-9 months. They would be destroyed unless I wiped them down every month or so. These are built on a 1/2" plywood back. It would be quit simple to encase them with a carcass and install a door.
- terrydowning
Dusty,
Any thought to leaving a vent hole in the bottom so dust drops out?? Just a thought as I'm thinking about storage solutions as well, and I rather like what you have for blades and such.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
Yes, there is an open bottomed air space behind the blade and disks. The panel is mounted to wedges that are in turn mounted to the back panel.terrydowning wrote:Dusty,
As you can see in the pictures, the two racks make good use of what would otherwise be dead wall space between the windows.
