out of round?
desperado
out of round?
Post by desperado »
Just got done turning a lid(Cherry) for a jar that belongs to my wife.
After sanding, it appears it is slightly out of round..
Is it me or the Shopsmith?
Thanx...Danny
davebodner
Post by davebodner »
Perhaps the wood shrunk as it dried after you turned the lid. Is the cross-grain diameter shorter than the long grain diameter?
mgdesigns
Post by mgdesigns »
If the wood was not dry enough, it will shrink differently in opposite directions. I've made quite a few bowls that were beautifully round, and after a few days to several months they turn into ovals. Only kiln dried wood has remained stable.
Hand Engraver of Metals; Maker of Exquisite Kindling; 1955 Greenie Mark V (NOW with a 1989 Headstock); Magna Band Saw; Magna 4" Jointer; Miscellaneous Craftsman & Porter-Cable electric woodworking tools.
3D CADCAM Designs - Gemstone Facetor
desperado
out of round
Post by desperado »
[quote="mgdesigns"]If the wood was not dry enough, it will shrink differently in opposite directions. I've made quite a few bowls that were beautifully round, and after a few days to several months they turn into ovals. Only kiln dried wood has remained stable.[/QUo
Thanx for the replies Mgdesigns and davebodner
The cherry i used is over 5 years old...
It just seems that when I'm turning there is a vibration and when I sand, there are about 2 places on the diameter that I can't correct while I'm sanding...
It's an old Mark V and i wonder if I should look at replacing bearings...
terrydowning
Post by terrydowning »
Replacing the bearings may be required. If it feels sloppy side to side or you measure excessive run out, then bearing replacement is indicated.
Sanding wood on the lathe can lead to a slight out of round condition. Long grain is softer than end grain and will wear faster. This is usually caused by excessive pressure applied when sanding.
To fix this condition (assuming it's not a bearing issue, and wood stability is not an issue)
Tool to use:
A sharp skew or Gouge
Cut to use:
Shearing type of cut above the center line (ride the bevel) using very light cuts (Listen to the wood as it cuts, you will hear the difference between an OOR piece and a round piece)
Once it is back to round sand very lightly if needed. A properly used skew or gouge should require very little sanding.
Just my thoughts on the subject, it's happened to me. Hopefully you can get a save if you have enough material remaining, otherwise, practice using the old one. When you're ready, make a new lid.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
