A few years ago I upgraded the bandsaw tires to the urethane tires. I have been having issues on and off ever since. Initially the tires seem to work fine but after a while (6 months to year) the tires start slipping on the wheels and walk themselves right off under the blade. Shopsmith replaced the first pair because when I measured them after having the problem they were too large. The assumption was that the tires I was sent were the wrong size.
I am now on my third pair of tires and have the same problem again. It appears that the urethane tires are stretching out over time and no longer hold onto the wheels. When new I have to remove the wheels and put in some effort to get the tires on the wheels. Now I can slip them back on the wheels without removal from the machine with little effort.
Am I the only one having a problem with the tires?
Any thoughts? Glue them to the wheels?
Thanks.
Bandsaw Tires walking off the wheels
- timsturnings
I guess I'll never buy the urethane tires if I ever need to replace mine now, thanks. I think some kind of stickum would probably help but it would need to be flexible. JMHO.
Seven days without turning makes one weak.
1952 Shopsmith 10er(restored)with Speedchanger,1952 Craftsman 10" table saw,Jet 1014 lathe(VS),HF VS 95607 Lathe,Craftsman Drill Press,55 Gal. Tornado Dust Collection System,Shop Wide Overhead Vac piping,WC slow-speed grinder,Wolverine sharp. system,Grizzly GO580 14" Bandsaw,Rikon Disk/Belt sander,HF Pressure Pot, JB 7 CFM Vac pump,TurnTex Stabilizing Chamber. (My 16' X 20' shop is full to the gills)
A couple of things that could cause the tires to stretch and come off the wheel -- running the saw too fast or applying too much tension. Once the tire is stretched, there's no shrinking it back to size. I don't know if adding adhesive to a stretched tire will work, but it may be worth a try. Perhaps someone else has tried that.
Art in Western Pennsylvania
