Sheave spring nut and washer
steve54
Post by steve54 »
My Mark five developed a loud screeching noise. I have found the issue or at least think I have. After getting the motor on the table. I removed the nut and spring and cleaned the shaft. Replacing the counter clockwise nut, the question came to mind, What holds the nut in place. I have read the forum enough to learn on some models there is a snap ring. Mine does not have a snap ring or a slot to put one in. What does hold the nut in place?
Learned alot just reading the maintenance section of the forum.
Thanks for any help.
Steve
steve54
follow up to sheave and nut ?
Post by steve54 »
The nut was finger loose when I disassembled the unit.
Thanks
The left hand threads prevents the normal loads from loosening the nut.
However the spring is what is trying to move the nut. It does not apply much torque to the nut.
The sheave is keyed, so it should not be torqueing the other end of the spring.
If the sheave was not sliding easily on the shaft, it probably was causing the belt to slip/squeal.
The floating sheave is what maintains belt tension.
beeg
Post by beeg »
steve54 wrote:My Mark five developed a loud screeching noise.
Steve
That screeching can also be caused by letting the motor sheave snap back, which reduces the needed space to keep it from rubbing on the housing.
steve54
sheave
Post by steve54 »
One final question, should I be able to compress the motor spring enough by hand to re-install the nut? I am just able to this by setting the motor on end and using the sheave plate to rotate the shaft?
Thanks again
beeg
Post by beeg »
steve54 wrote:One final question, should I be able to compress the motor spring enough by hand to re-install the nut? I am just able to this by setting the motor on end and using the sheave plate to rotate the shaft?
Thanks again
NO!!! Use the board and a dowel rod to reinstall the the spring and nut. Here's a PDF that may help, starting at number 8 and the spring board description at the top of the page.
[ATTACH]17740[/ATTACH]
replacing the motor spring.PDF
(292.02 KiB) Downloaded 274 times
