Texturing tools
lightnin
Texturing tools
Post by lightnin »
I'm considering buying these texturing tools
Can anyone tell me if they have used them and how they liked them?
I'm also dreaming of things I could use to make a variety of types.
Router bits... grinder dressing wheel parts...small gears
Bruce
Ok Ok, I'm up to four now...
foxtrapper
Post by foxtrapper »
I have not used those specific tools, but I have used similar.
Harder to do well than you would think. Do a second pass and you are almost guaranteed to not line things up correctly, resulting in a double strike imprint. Trying to go truly straight is ni to impossible. Trying to get perfectly parallel lines, with the texture matched is impossible, at least for this mortal. Wood hardness varies, meaning some woods are impossible to imprint well, even when you lean on the tool with everything you've got.
If you look around at your house, you've likely got a number of impression tools already. A screen roller, grinder stone dressing wheel, pie flueter, etc.
carverken
Post by carverken »
I have used the Sorby texture tool and the chatter tool. both with success. The texture would be diffent than the one you are looking at. Just a thought.
K
terrydowning
Post by terrydowning »
Based on the instructions, the standard Mk5/V may spin too fast. Bottom end is 700 RPM so unless it's a larger piece...
I have never tried though.
from the instructions PDF
Proper Lathe Speed
To determine an ideal lathe speed for texturing,
multiply the diameter of the work by 200 RPM. eg. if the
work is 2" in diameter, the recommended lathe speed
would be about 400 RPM. This is only an approximate.
Experiment with various speeds to find out what works
best for you.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
terrydowning wrote:Based on the instructions, the standard Mk5/V may spin too fast. Bottom end is 700 RPM so unless it's a larger piece...
Proper Lathe Speed
best for you.
~3 ft/sec?:eek:
lightnin
Post by lightnin »
Oh goodie.... I'll need a Power Pro....
When do they come to Lowes near me for the good deal?
Bruce
holsgo
Post by holsgo »
Hers a formula to get knurling tools to track for a second pass.
Measure the distance between the teeth. Normally at a diagonal.
The proper diameter of the workpiece is a multiple of the teeth spacing. You can still knurl diameters of the workpiece that aren't a multiple but you have to sneak up on it.
Just went through this making some handles on my metal lathe.
