Gilmer drive - silly question?
Hi All just been looking at Mickyd execellent restoration instructions for the Gilmer, (here's the silly question) how do you tell the difference between a glimer drive without a clutch and one with a clutch.
Just taken my '57 greenie apart and it looks like the one in his post but his pics show the gear part in two halves containing some discs. Mine is either so stuck it wont split or isnt supposed too. Help please?
http://www.shopsmith.net/forums/showthr ... #post32871
http://www.shopsmith.net/forums/attachm ... 1236933257
If this picture link does not work its the fourth image.
Thanks
Ian
Thanks
Ian
This link shows a picture of an early gilmer drive with no clutch.
https://forum.shopsmith.com/viewtopic.php?t=4925&highlight=gilmer+clutch
Thanks Ron it seems mine does have a clutch - now how to get it unstuck and back together as I haven't yet had a chance to use it. Only picked it up a couple of weeks ago in pretty reasonable shape but took everyones advice to 'strip her and oil up before using' - cant wait.rpd wrote:This link shows a picture of an early gilmer drive with no clutch.
Remove the bearing, remove the circlip, loosen the grub screw.iang wrote:Can't get photos till later but mine does look like Mickys the last photo link shows two Ali pieces at the bottom of the photo ( a gear and a collar with a grub screw) - mine will not separate or is there some special trick I'm missing to get them apart.
The clutch is spring loaded so should separate on its own, if not there may be some corrosion on the shaft. In that case try a few drops of Evaporust or penetrating oil to loosen it.
How many discs?
All apart!! Thanks. All the discs were stuck together, managed to separate them
and cleaned up the metal ones, the fibre discs are black and quite compressed but hopefully still usable as I am informed nigh on impossible to get in the UK.
Last question for now how many discs should there be - I only have three metal and four fibre.
it appears that mine breaks loose at 12 foot pounds. Is that too loose?
I'm anxious to finish the resto of my 56, but don't want it to slip to easily.
Anyone know the proper spec for the slipping to begin? I'm using a beam torque wrench to measure it.
www.wirewerkes.com
Hiding in a Joshua Tree.
See post #5 in this https://forum.shopsmith.com/viewtopic.php?p=32871#post32871 thread.wiredone wrote:it appears that mine breaks loose at 12 foot pounds. Is that too loose?
Mickyd said he was told "between 10 and 20 foot-lbs" by Bill Mayo.
