I just purchased a 1985 510 and am starting to clean it up, do alignment,etc. I've done a few 500s, so I know most of the basics.
My problem is what to do with black discoloration on all of the tables of the 510. I can't seem to make a dent in it. The discoloration seems to have penetrated into the metal much deeper than on the model 500s I've done.
Is some heavy-duty wire brushing the best bet? Or sanding it down? Chemicals?
Thanks!
Fred
Restore 510 tables? Black discoloration.
I don't know how to remove the discoloration. I don't even know for sure what it is. In fact, we don't even know if your discoloration is the result of the same thing as is the discoloration on my tables.fgrule wrote:I just purchased a 1985 510 and am starting to clean it up, do alignment,etc. I've done a few 500s, so I know most of the basics.
Thanks!
Fred
However, if it is anything like mine - I suggest that you are going to have to live with it unless you have the facility to mill the table top.
I have cleaned and polished and even used some abrasives without success.
That may well be the case (live with it). What I have tried so far (mild abrasives, aluminum cleaners, etc., has failed to help much).dusty wrote:I don't know how to remove the discoloration. I don't even know for sure what it is. In fact, we don't even know if your discoloration is the result of the same thing as is the discoloration on my tables.
Thanks, Fred
This may be 'wishful thinking', but I have used citrusstrip to clean up aluminum tables. Like Dusty said, we do not know what yer black stuff is, but if paint or plain old oxidation, citrusstrip may help.fgrule wrote:That may well be the case (live with it). What I have tried so far (mild abrasives, aluminum cleaners, etc., has failed to help much).
Thanks, Fred
MickyD used scotch pads on his and his tables look great!
Go to a welding supply store and try a product called Arcal Weldo
1957 Mark V - Shopsmith Bandsaw (This is my 5th. Shopsmith) First one Bought in 1975 -DC 3300 Dust Collector - Delta Table saw - Craftsman Radial arm Saw - Ryobi Planer _ Rigid Jointer - Dewalt Scrol saw - Grizzely 12" Belt 6x36 Belt sander - Craftsman Drill Press
John Pickett = Rushville Indiana
jppickett wrote:Go to a welding supply store and try a product called Arcal Weldo
Use with caution!!!
http://www.arcalchem.com/Pages/WeldO.html
http://www.arcalchem.com/Anonymous/Weld-O.pdf
The black is not paint. I'd say it's gotta be oxidation. I agree, I'll have to say no to the welding product (hydrofluoric acid is nasty stuff). I may try some phosphoric (already have it). Green Scotchbrite wouldn't touch it.JPG40504 wrote:Use with caution!!!
Anyone ever use Aluminox?
Fred
- fredsheldon
It's kinda like the warts on my face. I can spend a bunch to have them removed or just learn to live with them. It won't change who I am or how I act or perform, it would only serve to made me look better. And at my age, that's not important anymore
Fred Sheldon
The Woodlands, Tx
The Woodlands, Tx
