Just noticed that when my DC300 dust collector is running, it sends a plume of dust out the rear louvers! The bag is nowhere near full.
Must be something simple, but need to know what it might be before I disassemble the beast - a messy job under any circumstances.
TIA for your collective wisdom!
DC300: shooting dust out the rear louvers?
sawdust271
- Silver Member
sawdust271 wrote:Just noticed that when my DC300 dust collector is running, it sends a plume of dust out the rear louvers! The bag is nowhere near full.
You'll need to disassemble it, which isn't too hard. I think there are a couple of screws on the bottom back and a few inside.
You probably need to replace the seals, which are available from Shopsmith. There is a front seal around the cone that goes into the manifold and a real seal that is sold in two pieces around the back that keeps sawdust out of those louvers.
Otherwise, a visit to the hardware store to buy 1/4" to 1/2" weatherstripping works fine. Give some that you can compress tight to fit the gaps. It will cost less than $5 and you'll have some extra weather stripping left. The SS gasket will probably crumble under the lightest touch.
Give the collector a good cleaning while you are at it. Also run the motor while blowing air through the vent holes. It might be a urban legend, but everyone always says to may sure the motor is running while you blow it out.
Here is a link to another thread (the only one I've started) about the DC3300 and fixing the gasket.
https://forum.shopsmith.com/viewtopic.php?t=10448
- wlhayesmfs
Mine did the same thing and the old gasket fell all apart. I went to Ace and picked up some foam gasket and it now works good as new. I agree on the good cleaning while it is apart. You won't have it apart again for a long time.
Bill
Broken Arrow OK
Broken Arrow OK
letterk wrote:It cakes on the hood and gets everywhere in the machine.
Turn the DC3300 on and tap the hood to dislodge the cake buildup. Mine gets a buildup of INCHES of dust on the front left hand side.
sawdust271
- Silver Member
DCS300 - will disassemble
Thanks to all - I'm going to haul the thing out to the backyard this weekend and take it apart...
