I recently acquired a Shopsmith and so I've started lurking here
in the hopes of accelerating my learning curve.
I purchased a grab bag of arbors, router bits and miscellaneous components awhile ago.
A steel 12" sanding disc was included in the package.
Does anyone know how most sanding paper discs were bonded to face plates prior to the introduction of velcro ? What would be the best solvent to remove glue and old sandpaper without damaging metal finish ?
I was thinking of trying regular gas or naphta - kerosene, but thought I would ask here first.
The steel disc portion is black and the collar portion is finished like most standard Shopsmith arbors.
I noticed collars are a pretty snug fit on headstock shafts. Is it a good idea to grease or oil headstock shafts to avoid galling ? ... or is this only necessary on non steel to steel applications ?
I'm also looking for a 510 or newer lathe rest height adjustment post if anyone has a spare they might be interested in selling. The post I got with the included rest is a completely threaded style, found on earlier machines.
Thanks.
