Planer refurbishment
ryanbp01
Post by ryanbp01 »
Hi there-
It has taken awhile to recuperate to the point I feel comfortable enough to work in the shop. One oe my longstanding projects is to replace both the infeed and outfeed rollers on a Proplaner I bought used. My question is this: the instructions say to loosen 2 nuts by the motor and tighten the two lower nuts to remove the belt from the pulley. I am unsure about the nuts which the instructions are referring to.
BPR
lightnin
Post by lightnin »
Glad your feelin' better.:)
Bruce
Ok Ok, I'm up to four now...
ryanbp01
Post by ryanbp01 »
Bruce-
Thanks. I think shoulder joint surgeries are the worst to recover from. But at least I can now work on things without having to rely on pain killers. I didn't want to be on them while working on equipment.
BPR
fjimp
Post by fjimp »
ryanbp01 wrote:Bruce-
BPR
Wise fellow. Shoulder surgeries are great when they work. I pray you continue getting better. Follow the surgeons and PT's advise in every way. Protect that shoulder. If you injure it again you may find yourself unable to improve. Please I do not wise to be maudlin or sound negative I am truly thrilled your procedure is working well. I am one from that small percentage whom did not follow the program and have undergone two additional procedures. I am limited in what I can do and how long I can be active. Today my therapist informed me I have lost nearly 20% of the limited motion I had in the right arm. A reverse shoulder replacement is my only option and the prognosis from that procedure still offers crappy odds. Use care my friend and don't push yourself. Jim
F. Jim Parks
Lakewood, Colorado:)
