This is the first one I've seen.
http://www.ebay.com/itm/Shopsmith-mark- ... 19d5a1995a
SS Mark II
They come around less frequently, but still are around. A bit more limited in features and quality of build.
Here's a link to a discussion here about the Mark 2. Locally two showed up on Craigslist today, one for $50 and one for $100.
https://forum.shopsmith.com/viewtopic.php?t=6220
I bought one out of curiosity last year for cheap. Was a total waste of money,letterk wrote:They come around less frequently, but still are around. A bit more limited in features and quality of build.
other than the learning experience from taking it all apart and seeing how cheaply they were made.
www.wirewerkes.com
Hiding in a Joshua Tree.
Have no mercy? That bad? Not a Mk2 but look at this seller of a Mk5:wiredone wrote:I bought one out of curiosity last year for cheap. Was a total waste of money,
http://chicago.craigslist.org/nwi/tls/3307004746.html
Reads: Up for sale is an almost functioning shopsmith mark V. Motor runs and has brand new belts. Needs the dial that controls the speed ($10 on EBay). I don't need it and want it gone. Come get it today or I will saw it in half and give it to the scrappers. Call Mike at XXX-XXX-XXXX.
brad_nalor wrote:Have no mercy? That bad? Not a Mk2 but look at this seller of a Mk5:
Where is the drive hub that comes out of serial number plate? It looks like cover is loose and missing screws, but shouldn't there be a shaft even if the hub is missing? Yes, $10 and it will be right back to running.
letterk wrote:Where is the drive hub that comes out of serial number plate?
Looks like the cover is pulled back enough to hide the lower shaft.
