Does Shopsmith use a standard width slot or is their even a standard in the industry,
RICK
Width of t slot for shopsmith
onevw wrote:Does Shopsmith use a standard width slot or is their even a standard in the industry,
RICK
No, the Shopsmith miter slot is not standard. It is not even standard across the Shopsmith inventory. Some are slots only (no t-slot).
These are the dimensions that I use.
[ATTACH]18616[/ATTACH]
The miter track could be made wider, if absolutely necessary, by taking off just 1/64" on each side. This would make the miter track "standard" width (3/4") and would still work as a t-track. Shopsmith is not likely to do this (and maybe you should not) because the existing Shopsmith miter bars would no longer work (excessive slop).
- Miter Slot Dimensions (Custom).png (30.01 KiB) Viewed 10137 times
A bit for the SS track?
I was watching The Dusty Woodworker make a T-track directly into a wood piece, instead of installing a metal track. He used a router bit for this purpose. He said he thought there were many uses for a T-track directly into the wood.
My question? Has anyone ever seen a router bit that would replicate the SS T-track?
Wm. D. Elliott
Dallas, TX
1972 Model 500; upgraded to Model 7; bandsaw; belt sander; joiner; planer pro; power stand; OPR; Biscuit joiner; router tables
Dallas, TX
Here is a drill press table that has a t-slot, and it's process does not require any router. I am in the process of making a similar extension table and fence for my band saw using the dado'd slot with a hardboard cap.
http://www.woodsmithshop.com/download/2 ... stable.pdf
Brooks
SS Mark 5/520, Band Saw & Jointer SPT, DC3300
William, I don't think you'll find a T-slot router bit off the shelf that will match the Shopsmith T-slot in one pass. MLCS has one with the "T" portion that is 1/8" high, so you could match the Shopsmith slot with a couple of passes. Most of the others I saw were 3/16" thick, but one of those probably would do the job as well. You'd want to remove most of the stock with a straight bit before switching to the t-slot bit for cutting the slot. Alternatively, you could just remove the washer from the miter gauge so you wouldn't need to worry about the slot.
Art in Western Pennsylvania
A keyhole router bit(maybe).wdelliott wrote:I was watching The Dusty Woodworker make a T-track directly into a wood piece, instead of installing a metal track. He used a router bit for this purpose. He said he thought there were many uses for a T-track directly into the wood.
The bit that I have could cut a 3/16" 'tall' x 1/4" deep lip.
FWIW: The 10E/ER miter gauge bar is 3/4" x 7/32".
