Thanks
Thanks
Algale, db5, beeg, JPG40504, and greitz you guys are great. I tried all of your solutions. The real problem turned out to be the quill advancing slightly, enough to mess up a dado. The one solution that seemed to work the best was realigning the washer on the quill lock. I can't thank you enough your help it will make a little girl very happy when I get the finish on.
I am curious what you did to 'realign' it. Only thing I can think of is reversing the convex/concave sides in/out. Which way worked better?jack1943 wrote:Algale, db5, beeg, JPG40504, and greitz you guys are great. I tried all of your solutions. The real problem turned out to be the quill advancing slightly, enough to mess up a dado. The one solution that seemed to work the best was realigning the washer on the quill lock. I can't thank you enough your help it will make a little girl very happy when I get the finish on.
I honestly don't know. I took it apart and cleaned it, maybe I reversed the washer, but after that nothing moved except for rotation. The dadoes were straight. I do know that I did everything you guys suggested and something worked. The last step was the cleaning and reassembly of the quill lock.
Jack
Jack
Jack, this is why I seem to never get a lot better at some things! I do something and it works better than before, but I have no idea what I did different, therefore I cannot repeat the process.jack1943 wrote:I honestly don't know. I took it apart and cleaned it, maybe I reversed the washer, but after that nothing moved except for rotation. The dadoes were straight. I do know that I did everything you guys suggested and something worked. The last step was the cleaning and reassembly of the quill lock.
Jack
Dave
Dave
