Mark VII switch interlock lock and motor mount
The power switch is interlocked internally to prevent reversing direction without pressing the stop button. The key lock adds to that interlocking. The key must be in either the forward or reverse direction position in addition to the corresponding switch button being pushed. The lock also prevents any power switch depression when the key is removed. The lock has three positions - forward - off - reverse.
This shows the cam that is moved by the lock. The cam when moved away from the switch button(s) allows that button to be depressed.
lock interlock b4.jpg (106.61 KiB) Viewed 2788 times
The key interlock parts.
interlock parts.jpg (89.51 KiB) Viewed 2794 times
This shows the motor mount is different from the Mark 5/V in that one side is screwed to the front of the motor pan and the other side to the bottom of the pan.
motor mounting screws.jpg (107.59 KiB) Viewed 2784 times
This thread is linked to from https://forum.shopsmith.com/viewtopic.php?t=11373
