Bandsaw Question
Bandsaw Question
I built a bracket to hold a brush to clean debris off the badsaw blade. I can use a nylon toothbrush, brass or stainless brush from HF or some other option. The toothbrush is readily available but probably wears quickly. Not a big deal since I built this so that I can easily remove it and put on another if needed. But what works best for the blade and rubber tires?
- Brush Holder 2.jpg (92.26 KiB) Viewed 1936 times
- Brush Holder.jpg (67.3 KiB) Viewed 1925 times
Steel type wire brush will be fine. Check this blog, hope this will help
http://bandsawblog.com/415/
