dusty wrote:I have that same play and it causes no problem at all. I am not convinced, furthermore, that a new "drive and ring assembly" would eliminate the problem. The drive and ring assembly is not precision milled to mate with the spline on the shaft. I think there might be some play even with a new one.
While I had the standard headstock I fully agreed with Dusty's assessment. However, when I first installed the PowerPro DIY upgrade, I found there to be absolutely no play. The same was true with both rebuilds. After some use a very small amount of looseness ( hate to call it play) was sometimes noticeable when checking.
Like many Shopsmith users, I was not aware of any such play until it got large enough to first notice. Because, as said earlier, I was aware of this happening, I am now very aware of any changes here - believing the gaps in the drive ring and spindle flutes develop over time. Still no big issue!! just something to watch, (and fret about if you are so inclined).
With the relatively faster starting and stopping of the PowerPro, cant help but wonder if this will affect developing rotational play
