I've set up my late father's Mark V 500 as my main tool in my half of the garage. Sure is nice to be able to park a car in here as well - I love the small footprint of the Shopsmith!
While unpacking all the equipment, I've run across the "rubber bonded abrasive wheel." Although it's briefly mentioned in the Woodworking for Everyone book, I haven't seen anyone mention it when talking about sharpening tools, and it doesn't look like Shopsmith even carries it anymore. Is it any good? How would one want to use it? Thanks!
Rubber Bonded Abrasive Wheel
- a1gutterman
Hi jfran2,
Welcome to the forum.
I am not sure what it is that you have there, but would it work on this?
http://www.shopsmith.com/ownersite/itemfind.htm?item=555470&Submit=Find+Item
If not, I hope that you get your answer from others. Probably Nick would know.
Tim
- a1gutterman
Hi jfran2,
I can not find the diameter of the stones that they use with that grinder guard; however, there are three, and they look about 5" in diameter on pg 30, in the 2006 Mark V Accessory Catalog. I do not know what you would use your "stone" for though.
Tim
Now that I'm looking, I found this in the Woodtips Archives:
http://www.woodshoptips.com/tips/060302/page4.htm
It says it's just another way to hone tools! I just wonder how good it is!
- a1gutterman
After reading that Tip, I think that it would probably fit in the grinding guard, but you probably would have to buy an arbor for it too, unless you have one for it already.
Customer service can probably tell you if it will work that way; give them a call 1-800 762-7555.
Tim
