removal of lower bandsaw wheel
How does the lower wheel on the bandsaw remove? I want to put new tires on ,but I can't figure out the lower wheel.
[ATTACH]20000[/ATTACH]
The bearing is retained with a clip and screw accessible through the spokes.
30, 30A, 31
It may resist removal. Pushing better than banging. The bearing and shaft are not intended to be separated(IIUC).
30, 30A, 31
- band saw lower wheel clip.jpg (194.25 KiB) Viewed 4897 times
I would think removal would make cleaning the old adhesive more effective/easier.bosox wrote:You don't need to remove the wheel if you replace the tires. Pretty much stretched the new tires on. It was just easy for me when I replaced my old rubber tires with aftermarket Ultra Blue Urethane Tires.
But then I ain't done that(yet). Not looking forward to either!!!:eek:
Yes I be assuming glued rubber tires.
I assume you have done this. What size tires did you purchase and where?bosox wrote:It's better to upgrade to ultra blue urethane tires. Rubber tire needs gluing and requires you to clean the wheel.
Also why did you NOT clean any previous glue off?dusty wrote:I assume you have done this. What size tires did you purchase and where?
FWIW urethane tires melt if the blade gets too hot.
Guess I be stubborn, but I be 'sticking' with rubber.
I used to order with Carter before but my new one is from http://www.bandsawparts.com . I got 14 incher band saw and tire size is 7/8 .dusty wrote:I assume you have done this. What size tires did you purchase and where?
