I'm new to turning on my Shopsmith and already got tired of adjusting the tool rest using the allen wrench. Shopsmith offers a lever upgrade, http://www.shopsmith.com/ownersite/cata ... pgrade.htm, but I just swapped out the set screws for a couple of 5/16-18 ratchet lever handles (model MRXP63 from t-nuts.com). The lower handle has a 3/4" stud, while the upper is 1". Much nicer now. Sometimes it's the little things that make a big difference!
Darn it Ken!!;) Now I'll have to plan another purchase. Oh well, not too expensive.
Have seen this upgrade for several years, but couldn't figure how they would help. Now I find they have a ratchet capability. Hmmmm' didn't read enough, just looked at pictures.
Thanks for posting!:D
I'd like to here how the push-in ratchet works for this application. I have push buttons ones in use on my 10ER and the old OPR. The problem I find with them is when they are loose and then you attempt to ratchet they don't work very well. If you happen to have room to get them tight then the ratchet works well.
Some years back I had to make friends with the ones that I got from shopsmith that have the allen head. You can read about that here:
Those Shopsmith handles (parts 521688 and 521689) are very nice, Ed. With the exposed allen heads they would be much easier to routinely remove and reinstall, if necessary, than the ones I'm using. Cheap, too! Nice to have options.
I just received mine form t-nuts.com and put them on, boy they are nice. I ordered them 2/12 at 5:40pm and they came in the mail today. Now that is fast shipping. Thanks Ken for the post.
I just purchased the two from T-nuts and installed them last night. I found the top one wouldn't turn without the body hitting the arm of the tool rest because the plastic body has square (kind of) corners which will have to be sanded off. I'll look closer tonight and see if removing the corners will have any detrimental effects to the strength of the bolt mechanism.
kenbu wrote:Those Shopsmith handles (parts 521688 and 521689) are very nice, Ed. With the exposed allen heads they would be much easier to routinely remove and reinstall, if necessary, than the ones I'm using. Cheap, too! Nice to have options.
Ken
Yes it is nice to have options.
When adjusted properly it is almost like a switch, instead of "on" and "off" it is "tight" and "loose".
When I got my collection I got them a little cheaper by getting I think it was 10 of them. Needless to say that sounded like a lot but all of them found a home and I'll want to order a few more this spring. I'm trying to remember who I got mine from, perhaps lee valley??
