What is this? Mystery Accessory
midlifewood
- Bronze Member
I recently inherited a Shopsmith and in the collection of stuff that appeared to go with it was this set of pieces. They seem to be intended to go together and I believe it was intended for use on the Shopsmith partly because of the 5/8" bore in the black piece. This piece also has a set screw in it as does the silver piece with the 1/4" hole in it. I have asked Shopsmith customer service and one other chuck company if they know what it is and so far no one does. Any ideas?
- IMG_0418-1.jpg (141.06 KiB) Viewed 1282 times
- IMG_0426-1.jpg (120.14 KiB) Viewed 1264 times
- IMG_0425-1.jpg (123.98 KiB) Viewed 1241 times
reddog5362
midlifewood
- Bronze Member
It is a Sorby Chuck. After reading Reddog's response I did a little research and it is a Sorby Handy Collett Chuck. However, I seem to be missing several of the inner "jaws" that apparently came with it. I'm guessing that the one center piece that is there is intended to allow for using something like a 1/4" pen mandrel. I really don't have the need for this unit so it will probably end up on ebay as is. Thank-you for the assistance.
