Mark VII Carriage Breakdown
The Mark VII does not use a way tube spacer to position the carriage to the headstock(blade to slot etc.), but instead has a notched rod with three indexed positions. Resembles an arrow protruding from the carriage.:D
[ATTACH]20884[/ATTACH]
The rod is threaded and screws into the outer(bottom in the pix) side of the carriage. The carriage end of the rod is slotted to enable adjusting the stops. A jam nut secures it in position.
[ATTACH]20885[/ATTACH]
The table height lock nut and crank are similar(smaller) to Mark V 505-520.
[ATTACH]20886[/ATTACH]
The pinion gears are the same as all Mark 5 through Mark 7.
[ATTACH]20887[/ATTACH]
This thread is linked to from https://forum.shopsmith.com/viewtopic.php?t=11373
carriage b4.jpg (500.9 KiB) Viewed 5221 times
carriage a.jpg (454.42 KiB) Viewed 5223 times
carriage b.jpg (491.21 KiB) Viewed 5224 times
carriage c.jpg (449.2 KiB) Viewed 5219 times
Both pinion gears are merely pulled out from the carriage.
[ATTACH]20888[/ATTACH]
The pinion shaft resembles other models and has a c-clip on the rear end.
[ATTACH]20889[/ATTACH]
Now where have I seen a carriage lock similar to this?:rolleyes:
[ATTACH]20890[/ATTACH]
carriage d.jpg (489.64 KiB) Viewed 5219 times
carriage e.jpg (333.27 KiB) Viewed 5215 times
carriage f.jpg (495.83 KiB) Viewed 5214 times
First the locking nut must be removed. It is shallow and is not easy to move, so a good socket wrench must be used to 'adjust' or remove it.
[ATTACH]20891[/ATTACH]
Once the nut has been removed, I thought the shaft could be pushed out the front. However this stuff said otherwise. The collar behind the handle will not let the wedge pass through it. The collar is 'stuck' on a tension pin. Once it got 'unstuck', it all moved out the front.
[ATTACH]20892[/ATTACH]
This pix is to remind me how it came apart(so far).
[ATTACH]20893[/ATTACH]
And all the stuff in front disassembled. I do not yet understand the handle/white piece/collar function, but do know the handle steps fit against the white piece steps and the collar nibs go into the white piece slots, and the collar fits over the pin in the carriage. I am guessing the white piece creates a stop to prevent too much pressure to the wedges.* That long tension pin secures the handle to the shaft.
* Nope! The white piece provides a camming surface that squeezes the wedges together. The step is a 'loose' stop.
[ATTACH]20894[/ATTACH]
Mystery nubbin????
[ATTACH]20895[/ATTACH]
carriage lock a.jpg (503.55 KiB) Viewed 5211 times
carriage lock b.jpg (413.82 KiB) Viewed 5207 times
carriage lock c.jpg (255 KiB) Viewed 5200 times
carriage lock d.jpg (525.29 KiB) Viewed 5201 times
carriage lock e.jpg (472.64 KiB) Viewed 5202 times
Mike vonBuelow
Post by Mike vonBuelow »
My mystery nubbin has something protruding from it... any ideas what it is meant for?
http://www.shopsmith.net/forums/attachm ... 1410489605
Proud 24-yr USAF Veteran
COMPUTER: Dell Optiplex 620 - XP
LASER HARDWARE: Pinnacle 25W Mercury
CNC HARDWARE: Lumenlab MicRo CNC
WOOD TURNING HARWARD: ShopSmith Mark 7
SOFTWARE: Corel X3, CS4 Suite, Photoshop Web Suite CS3, Solidworks
FIRMWARE: My brain
Mike vonBuelow wrote:My mystery nubbin has something protruding from it... any ideas what it is meant for?
http://www.shopsmith.net/forums/attachment.htm?attachmentid=26176&d=1410489605
Looks like a tension pin. I will revisit the carriage tomorrow.
Mike vonBuelow
Re: Tension Pin - I talked with SS customer service, she had no idea what it's for...she even put me on hold to ask others - no answers! :eek:
FIRMWARE: My brain
Mike vonBuelow wrote:Re: Tension Pin - I talked with SS customer service, she had no idea what it's for...she even put me on hold to ask others - no answers! :eek:
Since mine also has the nubbin, I assume it was an abandoned design or has something to do with die casting. I also assume a PO put that tension pin in there.
i.e. stop fretting over it!;)
Did you really expect folks a half century removed from the initial design to have a concise, accurate answer?:rolleyes:
Re: Mark VII Carriage Breakdown
Post by Mike »
I think the tension pin is a stop for the pinion gear? See pic
I may be old but I’m slow
https://www.schmuckatellico.com/
https://scshiftknob.com
