My friend and I are redoing a greenie shopsmith. Got most of it done but am stuck, mainly because I don't even know what to call it. It is the part that you
use to raise and lower the saw table and the lathe. I have the shaft with the threads on the end. Have the spacer that will lock it and the geared thing but am missing the handle and the wingnut. If I know the proper terminogly I could see if Bill Mayo has extras that he would sell.
Thank you
Table lock parts
Handle and wing nut sounds appropriate enough!;) I assume that 'spacer' has a tapped hole for the 'handle'. A washer can be obtained at a hw store.anneb3 wrote:My friend and I are redoing a greenie shopsmith. Got most of it done but am stuck, mainly because I don't even know what to call it. It is the part that you
Thank you
