Since performing this true up I have performed several table alignments in table saw mode (blade to miter slot) -- but always with the table flat and have used the table saw many times without issue.
But I don't think I have cut many bevels since doing the true up. Yesterday I needed to rip a bevel in the edge of a 2 x 6 and it was slow going. I made a mental note to check the blade/miter slot alignment.
With the table level, the blade/miter slot alignment was "normal" which for me is anything under .005. But when I tilted the table to 45 degrees and rechecked, the back of the blade was almost 0.012 in!
Has anyone else who shimmed their table in drill press mode compared their blade to miter slot alignment with the table flat and with the table tilted? Have you noticed any heeling?
Al
