Hidden door bookcase ep 4 final installment
THOMRIDER
Post by THOMRIDER »
http://youtu.be/cSEGblgQ0jo
This is the last video in the series.
Check it out thanks.
SHOPSMITH 510, SHOPSMITH BANDSAW, AND MANY MANY MANY OTHER POWERTOOLS
mountainbreeze
Post by mountainbreeze »
Cool idea!!! Did you have to "beef up" the hinge mounting to the door/frame to support the extra load?
Bill
Mark V 520 50th Anniversary Edition, Planer, Jointer, Bandsaw
THOMRIDER
Post by THOMRIDER »
Thanks mountain. I did reinforce the hinge side to support the extra weight.
algale
Post by algale »
Neat project. How well does it hold books and do they stay put if you open the door or do you have to take stuff off the shelves before using it?
THOMRIDER
Post by THOMRIDER »
Should hold everything fine without removing anything.
I weigh about 250 and hung on the door for a bit and it didn't give at all.
THOMRIDER wrote:Should hold everything fine without removing anything.
How much will a full load of books weigh?;)
THOMRIDER
Post by THOMRIDER »
That's a good question,im not sure.
My daughter will have a mix of trophys and nick-nacks on the shelves who knows maybe a few books.
rpd
Post by rpd »
algale wrote:Neat project. How well does it hold books and do they stay put if you open the door or do you have to take stuff off the shelves before using it?
I suspect she will soon learn not to slam the door.;)
THOMRIDER
Post by THOMRIDER »
True Rpd, this is an attic access so the door will only see occasional use.
