Footswitch Question
db5
Footswitch Question
Post by db5 »
I'm considering adding a footswitch so that I don't have to reach down, turn on the shop vac and then the machine. I can do this with one switch while maintaining tactile and visual contact with the wood. I won't spend a lot of money and need to know how many amps it should be as well as other things to consider. I notice eBay has stuff ranging from $10 to $60 (for industrial stuff that appears to be much abused). If this is not a good idea tell me as well as your reasoning.
Muchas Gracias, Amigos. Si usted no habla espanol, puede quedarse rezagado when Congress passes the "Amnesty" bill.
joshh
Post by joshh »
Would this work for you instead? It's rated to 15 amps, just like the Shopsmith.
http://www.rockler.com/m/product.cfm?page=17351
My Spanish is rusty...is that:
Than you very much, friends. If you don't speak Spanish, you can stay behind when Congress passes this "Amnesty" bill.
friscomike
Post by friscomike »
Howdy,
Shopsmith offers a cool remote switch which I use on the dust collection system. I keep it in my apron and turn it on when I turn the Shopsmith on: http://www.shopsmith.com/ownersite/cata ... switch.htm.
Best, mike
...now, if you'll excuse me, I'm a busy man. I have sawdust to make... ;)
I've had a Craftsman load-sensing switch for a few years now. Works swell. It senses the current when you turn on a power tool plugged into the primary outlet, and it then turns on the auxiliary 110V devices, be they lights or vacs.
http://www.sears.com/craftsman-auto-swi ... 924031000P
I normally have all my power tools, including my SS, running off the primary outlet. The switch turns on the auxiliary (vac) devices immediately when I fire up a power tool. When I turn off the power tool, it lets the auxiliary devices run for a couple more seconds, then turns them off.
My only beef is that there is no override mode to run a vac independently. If I just need to vac the floor, for instance, I either have to run a power tool, or more appropriately, move the vac plug to a primary outlet.
[quote="BuckeyeDennis . . .
My only beef is that there is no override mode to run a vac independently. If I just need to vac the floor, for instance, I either have to run a power tool, or more appropriately, move the vac plug to a primary outlet.[/quote"]
Seems like a simple enough thing for a EE to overcome!:D
Using:
http://www.shopsmith.com/ownersite/c...ess_switch.htm.
ryanbp01
Post by ryanbp01 »
friscomike wrote:Howdy,
Best, mike
I like mine as well. I took the foot switch and put it on my DeWalt Scroll saw.
BPR
JPG40504 wrote:Seems like a simple enough thing for a EE to overcome!:D
Using:
I get your drift. Wire-OR'ing two AC sources would get the job done quick and easy. But I also have a nagging feeling that it would violate code without a proper enclosure, and so should probably say no more. Reminds me of the PhD at work that once ginned up a 240V outlet for a test fixture by connecting up just the right two 120V outlets .. :rolleyes:
But you are making me strain my brain during my off hours. :( Ouch! I'd much rather be contemplating the most gorgeous hunk of wood that I have ever seen for sale. http://www.ebay.com/itm/121124550280?ss ... 1438.l2649
Well, there went my hopes of picking that one up for cheap. :D
BuckeyeDennis wrote:I get your drift. Wire-OR'ing two AC sources would get the job done quick and easy. But I also have a nagging feeling that it would violate code without a proper enclosure, and so should probably say no more. Reminds me of the PhD at work that once ginned up a 240V outlet for a test fixture by connecting up just the right two 120V outlets .. :rolleyes:
But you are making me strain my brain during my off hours. :( Ouch! I'd much rather be contemplating the most gorgeous hunk of wood that I have ever seen for sale. http://www.ebay.com/itm/121124550280?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
One source, two paths. Enclosed of course! Polarized plugs etc. an absolute requirement. Mind yer polarity!!!!!
