Back in the Machine(ist Chest) Shop
nuhobby
Post by nuhobby »
It's been a while since I've had a project to do. Also some extra stress at work lately, so it was time for some "happiness dividends" from the Shopsmith. I have obtained another (my 4th) old machinist chest to restore. I have completely busted it down and have been fixing various components before getting it back together.
It's to the point that the front-panel has to be rebuilt before I can put any more pieces back together. While this is a quality box, I didn't like the look or feel of the plywood center-panel.
I've chosen, resawn, glued, and dressed a piece of Kentucky CoffeeTree wood for the center panel. After bandsawing to rough size, I'm tuning in the dimensions and squared edges with a shooting-plane gadget I made one day last year:
[ATTACH]21935[/ATTACH]
Now it's over to the OverArm Router station to do some rabbeting on the back face, and coving the edges on the front face of the panel:
[ATTACH]21936[/ATTACH]
As it happened, I messed up one edge a little bit. I was able to obscure the fault with a chisel, and also choose an orientation which will hide the fault in a natural "shadow" area of the assembly. Finally I've trimmed the last edge to allow just a big more room for cross-grain expansion/contraction inside the frame:
[ATTACH]21937[/ATTACH]
Now the glue-up is clamped for the frame, the front-panel of the machinist chest. Once this is done, I can slowly start many other pieces of re-assembly. On this chest, the front-panel will have pivot-pins that keep it trapped in grooves in the main carcass:
[ATTACH]21938[/ATTACH]
On to another overdue job; I needed a little wood wheel. I've had a fly-cutting hole "drill" for years, but in the 700rpm days it was kind of scary. Now the PowerPro lets me do 250rpm, which was a nicely controlled operation:
[ATTACH]21939[/ATTACH]
Sure felt good to have my hands busy again!
Squaring Panel.jpg (113.57 KiB) Viewed 28821 times
Rabbeting Panel.jpg (109.91 KiB) Viewed 28829 times
Tweaking Edges.jpg (113.89 KiB) Viewed 28838 times
Frame Glue_Up.jpg (111.44 KiB) Viewed 28830 times
Slow Hole Drilling.jpg (104.58 KiB) Viewed 28825 times
Chris
Ed in Tampa
Post by Ed in Tampa »
Beautiful wood!!!!!!!!!!
Ed in Tampa
Stay out of trouble!
nuhobby
Post by nuhobby »
I did a few more "loud jobs" today while the wife was busy outside. My usual accommodation is to do quiet hand-work while this sensitive soul is in the house.
As I can do for all but the thickest/hardest woods, I just resaw my white oak right against the stock bandsaw fence, works great!
[ATTACH]21946[/ATTACH]
Now I'm using my tiniest router-bit, 1/16" diameter, to do some slitting:
[ATTACH]21947[/ATTACH]
The result is some stock I can use to make up a missing front-panel on one of the drawers of the machinist chest:
[ATTACH]21949[/ATTACH]
Off-line, I had removed rotted veneer from the top lid of the chest, and glued on some quartersawn oak veneer:
[ATTACH]21945[/ATTACH]
As I get back to some fine detail work, I like to handsaw my crosscuts manually. I've fixed up an old miter box and sharpened that saw -- it cuts very nicely. A missing piece was a sacrificial wheel to keep the saw from going too deep or otherwise out of control. Here's the wheel I made in the last posting:
[ATTACH]21948[/ATTACH]
A slow project, but coming along!
Case Top Re_Veneered.jpg (99.89 KiB) Viewed 28693 times
White Oak Resaw.jpg (98.92 KiB) Viewed 28771 times
Slitting with OPR.jpg (99.08 KiB) Viewed 28739 times
Sacrificial Wood Wheel.jpg (81.4 KiB) Viewed 28690 times
Drawer_Front Stock.jpg (58.32 KiB) Viewed 28731 times
Chris
nuhobby
Turning the Corner
Post by nuhobby »
A few more steps done this morning....
I had cached up a bunch of vintage junk to de-rust all at the same time. Included in this were the pivot-pins at the bottom of the front-trim panel on the chest...
[ATTACH]22026[/ATTACH]
The oak piece that I profiled last week, I hand-cut and mated to the bottom drawer. I'll be doing a bit more strengthening on that drawer yet. In all the chests I've worked on, the biggest/lowest drawer always has the most wear on its components and runners:
[ATTACH]22027[/ATTACH]
With the de-rusted pivot pins, I was ready to commit the front-panel into the assembly, and glue the lower-corner box-joints (as well as plywood back panel, still without veneer for now) into a mighty carcass!
[ATTACH]22028[/ATTACH]
Now out to enjoy some fairly cool June weather this morning. The 50-year-old chest can wait a little longer to complete :) .
Derusting Bath.jpg (108.43 KiB) Viewed 28603 times
Back to 11 Drawers.jpg (109.08 KiB) Viewed 28600 times
Carcass Glue Up.jpg (104.08 KiB) Viewed 28573 times
Chris
nuhobby
A Pox Upon the Veneer!
Post by nuhobby »
Uggh, not the cleanest / best part of the job.
I've kept the factory plywood back-panel, since it has to have stable dimensions. The outer oak play was mostly gone, so I'm cleaning/scoring the under-layer and adding fresh veneer. Well, it's OK, but it's had bubbles that I needed to pierce and re-glue.
I'll forget about that trouble when the next trouble comes along ;) .
[ATTACH]22031[/ATTACH]
Back Veneer.jpg (111.61 KiB) Viewed 28516 times
Chris
jere
Post by jere »
Great work! So much so I think I am going to try making a box like yours. I don't have anything close to your experience, do you have any pointers? Also, how do the drawers slide in the main box? I don't see any slides like in a kitchen drawer/metal toolbox. Are there carved tracks maybe?
nuhobby
Post by nuhobby »
jere wrote:Great work! So much so I think I am going to try making a box like yours. I don't have anything close to your experience, do you have any pointers? Also, how do the drawers slide in the main box? I don't see any slides like in a kitchen drawer/metal toolbox. Are there carved tracks maybe?
Thank you! Work is coming along. For the chests I've worked on, the several drawers have dados on their side-walls. The cases usually have strips of hardwood to mate with the drawer-dados. However, one chest I worked on had some metal bars nailed to the case walls.
Due to the wood interface, these drawers have a nice sensory aspect when you move them, sort of a silky feel.
Chris
danscot
Post by danscot »
These chests are very impressive when you have them finished. I'm looking forward to seeing the end result with this one - seems to be more involved in it!
Are the drawers designed to be pulled out completely or are there stops of some kind to prevent that?
nuhobby
Post by nuhobby »
danscot wrote: Are the drawers designed to be pulled out completely or are there stops of some kind to prevent that?
For the vintage models I've worked on, all the drawers can come all the way out. I have read somewhere that modern production at Gerstner & Sons has a drawer-retainer feature to address complaints of drawers falling out, but I've not yet seen one in person.
I also think the modern Gerstner production has diversified in terms of drawer sizes. There are probably less people out there with dozens of metal-working cutters and mills, and more folks having other types of collections. I know my one nephew keeps a bunch of authentic Zippo lighters in his chest.
Chris
nuhobby
Tarnation! and more gluing
Post by nuhobby »
Now more progress, but some of my mistakes are coming after me....
Here is the hardwood reinforcement I'm doing on the big drawer's dado runners. I use a 1/4" drill lightly wrapped in wax-paper to help align the new stock:
[ATTACH]22083[/ATTACH]
I had become a fan of using brown Briwax to accentuate the open grain of Oak. Not bad in so far as that goes, but the new bookmatched Coffeetree front-panel had some planing insufficiencies that I've now highlighted for the next 50 years :mad: . TAR- nation! Anyway, hardware riveting and felt-gluing is coming along....
[ATTACH]22084[/ATTACH]
Drawer Runner Reinforcement.jpg (61.96 KiB) Viewed 28346 times
Top Felt Gluing.jpg (107.68 KiB) Viewed 28339 times
Chris
