Belt Sander question #2
- cincinnati
I have watched the video but have a question about the table position. The catalog says the table can be placed on the side of the belt. The only photo I see with the table on the side is with the use of the drum sander. Am I correct that the table can be used on the side with the belt? Is there a photo on the web that show this?
Also what is the table made of? Cast Iron or aluminum?
"Am I correct that the table can be used on the side with the belt?"
Yep.
"Is there a photo on the web that show this?"
Nope.
"...what is the table made of?"
Cast iron.
With all good wishes,
Yep.
Nope.
Cast iron.
Nick Engler
http://www.workshopcompanion.com
- cincinnati
Here you go Cincin,
- One pix shows the table perpendicular and the smallest of the SS drum sanders attached to the spindle via a drill chuck. The other snapshot shows the table on the side in vertical position with the largest of the drum sanders attached to the spindle. Intended to also include a picture of the miter gauge located in the table slot, but was too lazy to remove the miter extension from the gauge. Incidentally, the miter gauge can be temporarily fixed to the table by tightening the slot adjustment screw.
[ATTACH]895[/ATTACH]
[ATTACH]896[/ATTACH]
- HPIM1693.jpg (115 KiB) Viewed 17176 times
- HPIM1694.jpg (124.25 KiB) Viewed 17182 times
- cincinnati
- a1gutterman
- cincinnati
[quote="Nick"]"Am I correct that the table can be used on the side with the belt?"
Yep.
Nope.
Not true http://www.woodworkingbeltsanding.com/page2.htm
Yep.
Nope.
paulmcohen
cincinnati wrote:Nick wrote:"Am I correct that the table can be used on the side with the belt?"
Yep.
Nope.
That Photo looks it was taken before Nick was born.
Paul Cohen
Beaverton, OR
Beaverton, OR
