Sawsmith Radial Arm Saw
wasatch
Post by wasatch »
Has anyone ever used a Sawsmith radial arm saw? If so, was it any better then every other 10" radial arm saw? Is there anything different about it over other brands?
wasatch wrote:Has anyone ever used a Sawsmith radial arm saw? If so, was it any better then every other 10" radial arm saw? Is there anything different about it over other brands?
Variable speed. Takes SS attachments and spts.
opus139lsb
Post by opus139lsb »
I bought a Saw Smith about 3 weeks ago that was listed for $40.00 in the Cleveland, Ohio craigslist. For a machine designed more than 50yrs ago it is really built! Super heavy duty stand, a power head that can mount the blade left or right of the motor, the power head rotates 90 degrees from vertical to horizontal , 6 speed control settings, can use assorted SS attachments ,20" bed travel on the y axis.
I will take the machine apart , rebuild and restore the colors as when new.
A quick test of the motor was great with no bearing noises or smoke.
wasatch
Post by wasatch »
Does it use saw blades with the 1 1/4" arbor?
joshh
Post by joshh »
- 1986 Mark V 500 Mini
- 1985 Mark V 510 with reversible motor, bandsaw, jointer, and double-tilt.
I offer quality motor reversal, rebuilding, and rewiring. Contact me at HarbourTools@live.com
SDSSmith
Post by SDSSmith »
wasatch wrote:Does it use saw blades with the 1 1/4" arbor?
It can with the Sawsmith 1-1/4" saw arbor. This special arbor allows mounting the blade on either output shaft. Otherwise, you can use 5/8" bored blades on either side of the machine.
Rob in San Diego
