Part A connects to Part C?????
Gene Howe
Post by Gene Howe »
Finally got the new to me shopsmith unpacked and all the parts laid out.
Thanks for the great packing job, Bill!
After poring over an exploded parts diagram, I got one part, a leg, assembled.
I have my original Shopsmith right in front of me as a reference model, an exploded parts diagram too, and I still find pockets (make that buckets) of befuddlement. An ME, I’m not.
And the wife doesn't understand why I have a problem putting the pups’ halters on right.
Gene
If the parts on the floor are not positioned in the same direction as the parts in the pictures, I have the same problem.
Wiring the plug on the travel trailer to connect with the plug on the truck was a lot of fun.
Gene Howe
Post by Gene Howe »
Lucky the other 'Smith was handy. Got everything except the table assembled. Get that done after lunch.
I don't remember the motor being that heavy,:o
I did the trailer/truck rewire once. Don't never want to again! :eek:
Good luck!
Gene
Standard truck/trailer wireing
Fortunately there is a starndard way to wire ALL Truck connections to ALL trailers. If followed, switching trailers or pull vehicles never becomes a problem.
Scroll down the page for colored diagrams. http://www.etrailer.com/faq-wiring.aspx
It's nice to be able to pull the boat trailer or the snowmobile trailer or the utility trailer with any tow vehicle.
I am embarrassed to say that I have that diagram and I understand it.:o
It is when I look at the diagram so see which pin to use and then go to the connector to connect the wire (looking from the other end) that gets me screwed up.:rolleyes:
That and the fact that my old trailer dates back to sometime before standard configurations. Examples: I have orange and purple wire in the trailer harness. There is no orange or purple in the standard.:eek:
dusty wrote:I am embarrassed to say that I have that diagram and I understand it.:o
????? They are pictured both ways???????? Look at the 'right' one.:D
JPG40504 wrote:????? They are pictured both ways???????? Look at the 'right' one.:D
Yeah. I know that. I told you I get all screwed up.
Hmmm, must be old age.:eek: No, it can't be that. Charlese doesn't have this problem.
Gene Howe
Post by Gene Howe »
It ain't age, Dusty. I've had that problem since I smashed my Tinkertoy set.
OTOH, THE 'SHORTY' IS ASSEMBLED and it works!!!
Gene
Gene Howe wrote:It ain't age, Dusty. I've had that problem since I smashed my Tinkertoy set.
Congratulations. I have good reason to believe that you will get almost as much use out of your shorty as you do the Mark V. "I am addicted" to mine.
dusty wrote:...
Oh yes he does!!;) My Son is an accomplished mechanical engineer. He told me it is a common problem for engineers. They call it mirror image.
Yes - I think we all have it when least expected:eek:
That's why diagrams are so helpful.
