Bandsaw Revisited
gr8mesquite
Bandsaw Revisited
I've decided to try again to make friends with my band saw. One thing I have learned thru my fumblings is that band saw blades have to be "out of the box" sharp to perform satisfactorily on hardwoods, especially woods like mesquite, jatoba', cocobolo, et al . Also, they will go dull pretty quickly on these woods and begin to drift all over the place. My conclusion has been to buy cheap blades and throw them out without hesitation, as opposed to buying "better", more expensive, blades that don't last 3x longer given the 3x price tag. For example, I bought a Highland Hardware Wood Slicer Resaw Bandsaw Blade for $30 plus shipping, and it didn't last any longer than the Olson Flexback I bought on sale at Woodcraft for $10.
Which brings me to my inquiry:
I noticed today that there are 2 (at least) manufacturers making carbide tipped band saw blades that will fit Shopsmith. Lenox makes a Lenox Tri-Master Carbide-Tipped 1/2 inch Bandsaw Blade which runs about $100, and Magnate ( http://www.magnate.net/index.cfm?event= ... theID=1438 ) make one that runs about $93 (1/2" 3 tooth rake cut.)
Has anyone used one of these? Does it outlast a plain old flexback by 9-10X? Can it be resharpened? At what cost?
I'm anxious to hear your thoughts, because I'm excited to buy one of these.
Thanks
Jerome
Thanks
Jerome
I suspect that since you are anxious, you ought to go get one each of those and perform a comparative analysis. Waiting for one of us might be a long wait.gr8mesquite wrote:I've decided to try again to make friends with my band saw. One thing I have learned thru my fumblings is that band saw blades have to be "out of the box" sharp to perform satisfactorily on hardwoods, especially woods like mesquite, jatoba', cocobolo, et al . Also, they will go dull pretty quickly on these woods and begin to drift all over the place. My conclusion has been to buy cheap blades and throw them out without hesitation, as opposed to buying "better", more expensive, blades that don't last 3x longer given the 3x price tag. For example, I bought a Highland Hardware Wood Slicer Resaw Bandsaw Blade for $30 plus shipping, and it didn't last any longer than the Olson Flexback I bought on sale at Woodcraft for $10.
I noticed today that there are 2 (at least) manufacturers making carbide tipped band saw blades that will fit Shopsmith. Lenox makes a Lenox Tri-Master Carbide-Tipped 1/2 inch Bandsaw Blade which runs about $100, and Magnate ( http://www.magnate.net/index.cfm?event=showProductGroup&theID=1438 ) make one that runs about $93 (1/2" 3 tooth rake cut.)
Thanks
Jerome
gr8mesquite
Seems to me if you are using "standard" blades on extraordinary materials you are not using the right tool.gr8mesquite wrote:I've decided to try again to make friends with my band saw. One thing I have learned thru my fumblings is that band saw blades have to be "out of the box" sharp to perform satisfactorily on hardwoods, especially woods like mesquite, jatoba', cocobolo, et al . A...
Jerome
The cost of the blade is probably proportional to the cost of the material, too. So I would consider the purchase of the Super Blade to be justified for the Super materials. The bottom line is the finished product, no? Despite the expense incurred in producing it?
gr8mesquite
gr8mesquite
[ATTACH]23038[/ATTACH]
I did my maintenance and mounted the blade today. Yikes...it's like cutting butter with a hot knife. I had a block of oak, and I moved the fence as close as possible to the blade. I thought I was cutting a piece of pine. I don't know if you can see it, but the 2 veneers are really thin and bendable. The surface is pretty smooth, but would need finish sanding if I were using it. I'm impressed so far.
Jerome
Jerome
- DSC04450.JPG (43.83 KiB) Viewed 4073 times
Very nice! Will be interesting to see if it stays sharper longer. Let us know.gr8mesquite wrote:[ATTACH]23038[/ATTACH]
Jerome
So! Howcum no drift?:D
gr8mesquite
Actually I was commenting on the apparent lack of it.gr8mesquite wrote:Don't know if you're kidding, but it was uncanny. I just set up the fence and cut--no drift alignment. I could stand to square the blade and fence a little better, but no drift.
Jerome
I am biased in that I consider much 'drift' to be caused by alignment.(not all, just much of it)
Annnnd the lack of a need to push aggressively when feeding.
