Attempted to plow a dado with a 1/4" router bit w/ a 1/2 shank. 1/4" deep with the only dust escape through the dado.
Bit broke off after 18" due to the heat build up.
Good thing it was contained.
Lesson learned!
Don't tell anybody. I'm abashed, ashamed and contrite.
Gene
Gene Howe wrote:Attempted to plow a dado with a 1/4" router bit w/ a 1/2 shank. 1/4" deep with the only dust escape through the dado.
Lesson learned!
I find I can do cuts like this but I like to use a carbide spiral bit which ejects the material. Of course the material you are cutting and many other factors come in to play.
Glad you were not injured, perhaps it is time to just get another bit and get on with life and the project. No need to beat yourself up, stuff happens.
You're not the Lone Ranger here, Been there, done that also, Gene:o Now take only 1/8" or so per pass. The bad part of doing that is the tip of the bit wears out quickly.
I also find it impossible to sharpen spiral bits and they also wear quickly at the tip.
So now use the dado blade on the saw.
charlese wrote:You're not the Lone Ranger here, Been there, done that also, Gene:o Now take only 1/8" or so per pass. The bad part of doing that is the tip of the bit wears out quickly.
EGGZACKLY!
I knew about 8" into the cut that something wasn't right. I gotta start listening to those little voices.
Gene
Ed in Tampa wrote:What was the brand of the bit?
I think there was more to this than heat build up.
No, This is not the manufacturers fault!:rolleyes:
