cabinet door construction
I have recently aquired a Shopsmith bicuit jointer and will be building a few test panel doors. I was considering a rail and stile joint but the biscuit looks a lot easeir and I don't need expensive router bits.
Any success storier using either type of connection or something else that works well. I plan on building about 20 kitchen cabinet doors with a panel insert.
I too prefer stub tenon and groove doors if I'm want a flat panel door. Some call it a "Shaker Style" door and it is currently in vogue. Plus, there is no need for biscuits or router bits. I've attached a simple plan if you are interested.
Frame and Panel Doors.pdf
- (822.22 KiB) Downloaded 967 times
Abraham Lincoln
Abraham Lincoln
- Ed in Tampa
I have built cabinet door just about every way you can think of. I got a rail and stile bit set and to me that was easiest. Had to watch for tear out but the finish product was worth the cost of the router bit set.
I like biscuits but I don't use them like I once did. They almost seem like they are "the way we used to do it." method. As production shop type tools an bits become available and cheap enough I switch to them.
Rail and Stile router/shaper bit set is fast accurate and easy and almost fool proof. Once setup you can push wood through at surprising rate and cabinet doors become almost a no brainer.
Ed in Tampa
Stay out of trouble!
- Ed in Tampa
No I bought mine from Infinity that happens to be here in Tampa. They weren't adjustable as such you buy a matching set and they make all the cuts even the groove. Easy as pie. I got mine on closeout years ago and they have served me will.mgbbob wrote:Hi, Did you purchase the adjustable Rail/Stile bits and if so what brand? In the short term I think I will try a couple of test doors with the stub tenon and biscuits.
Thanks,
Initial setup can be tricky but I created a jig that I keep that I can set the height perfectly in one try. The jig is nothing more than a block of wood cut by each bit after they were perfectly set up the first time. I set the block on my router table and adjust the bit to fit the wood block and I have a perfect setup. NO fuss no mess.
The bit are big and have a large cutting surface so the hold their edge really well. And being Infinity bits makes that even more true.
Ed in Tampa
I've built a number of cabinet doors for my house and my garage. I bought the Shopsmith rail and stile bits. They make the job of making the frames easy. On the center panels, I've tried a number of different router bits, and even the table saw cutting an angle on the face of the panel. They all work.
The rail and stile bits make for easy assembly and simple fit with just a little wood glue.
