Curious-Power Pro upgrade Question
chucks
Post by chucks »
Has anyone upgrade the old Mark VII to the Power Pro?
Chucks in Phoenix Mark V(5), Mark VII(2),Power Pro, Planer, Crafter Station, Jointer,Bandsaw(3),Lathe Duplicator,Belt Sander,Jig Saw,DC3300(2),"Sears Router Crafter", Post Drill, Stand alone Overarm Router. Jointmatic ++++,
chucks wrote:Has anyone upgrade the old Mark VII to the Power Pro?
One would have to fabricate different mounts for the motor and control board.
The control panel mounting also.
The spear would have to go bye-bye.
The idler shaft may present problems(the eccentric od is larger on the VII).
As a first look that is what I see as 'issues' to be resolved as seen from afar.
Interesting thought!!!:cool:
chucks
Post by chucks »
Thank you Sir.....;the Power Pro weight would probably have been to much for the old rack on the Mrk VII anyway.(Would have been nice though.)
chucks wrote:Thank you Sir.....]the Power Pro weight would probably have been to much for the old rack on the Mrk VII anyway[/B].(Would have been nice though.)
Why????
The Mark V/7 tubes are thinner IIRC. At the very least they are the same!
chucks
Post by chucks »
I was referring to the plastic rack(Gear track or what ever the proper name is) Moving the addition wight of the Power Pro headstock using it may have ended it's life a bit quickly.
chucks wrote:I was referring to the plastic rack(Gear track or what ever the proper name is) Moving the addition wight of the Power Pro headstock using it may have ended it's life a bit quickly.
I doubt that 'extra' weight would affect it.;)
However they do get 'brittle'.
