Hello all.
Im looking for the video where Nick used Murdic acid and a heat gun to make a fake aged look on new wood.
Thanks in advance.
C.A.G.
hands online video help
curtis george
- curiousgeorge
I have posted this in the past and I'm sure it would be hard to find now. So, here it is again. It is a PDF index to the Sawdust Sessions. Simply open the PDF, find the session you want to view and click on the title. If all works correctly, you should be taken to that session...
[ATTACH]23792[/ATTACH]
Sawdust Sessions Video Index.pdf- (72.92 KiB) Downloaded 446 times
George
Ft. Worth, TX.
Go TCU Froggies
Ft. Worth, TX.
Go TCU Froggies
Thanks from me. Just downloaded it.curiousgeorge wrote:I have posted this in the past and I'm sure it would be hard to find now. So, here it is again. It is a PDF index to the Sawdust Sessions. Simply open the PDF, find the session you want to view and click on the title. If all works correctly, you should be taken to that session...
Dan
Start a thread with that title.curiousgeorge wrote:I have posted this in the past and I'm sure it would be hard to find now. So, here it is again. It is a PDF index to the Sawdust Sessions. Simply open the PDF, find the session you want to view and click on the title. If all works correctly, you should be taken to that session...
Then, put that link in the first post.
curtis george
