Hello,New member from WNY
paulsgreenbarn
Post by paulsgreenbarn »
Helo everyone.I just bought a SS markV 510 with jointer,belt sander,scroll and band saws as well as the 5:1 and dust collector.i look forward to getting to know the machine.
I build furniture for a living .Most from Reclaimed Barn wood.i have a facebook page under Paul's Green Barn.i lost my shop to a fire in December and i'm loooking for this 510 to allow me to continue building while replacing my shop.?I hope it works well as I'm thinking of getting a couple more 510 or 520 power units as work stations for myself or any helpers.My new shop will be built on the leftover deck of my old and measure 20'x40'.
i look forward to learning from you all and seeing the work you do with your ShopSmiths.Thanks
paulsgreenbarn wrote:Helo everyone.I just bought a SS markV 510 with jointer,belt sander,scroll and band saws as well as the 5:1 and dust collector.i look forward to getting to know the machine.
Welcome!
Do not overlook the older models for work stations. Yes that includes the model 10.;)
joedw00
Post by joedw00 »
Welcome to the forum. Sorry to hear about your shop.
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
paulsgreenbarn
What would you say the best uses are for the old Green 3/4hp units as a work station?I'm guessing lather and drill press?
paulsgreenbarn wrote:What would you say the best uses are for the old Green 3/4hp units as a work station?I'm guessing lather and drill press?
Sanding station, bandsaw, jig/scroll saw, shaping . . . just about anything other than table saw. Nice thing about the SS, one SS can do all those things although not simultaneously. A good way to get back to normal with less $.
Bill Mayo claims the 3/4hp motor is near the same as the 1 1/8 hp motor. Most operations do not require 1hp +.
billmayo
Post by billmayo »
JPG40504 wrote:Sanding station, bandsaw, jig/scroll saw, shaping . . . just about anything other than table saw. Nice thing about the SS, one SS can do all those things although not simultaneously. A good way to get back to normal with less $.
Very true. Almost all my personal Shopsmiths have used the 3/4 HP motor. During my time of motor testing, I found most 1 1/8 HP motors only had up to 10% more power/torque than the 3/4 HP motors. I found that the 1 1/8 HP motor did help when using the thickness planer or sawing hardwoods or when using a dull saw blade. Many of the SHORTY and MINI Shopsmiths I sold had the 3/4 HP motor which was reversible so a SPT could be mounted on both ends. I should say that I found the early cast iron AO Smith 3/4 HP motor (54-55) provided the most torque and could handle higher current draw ( over 15 AMPs) under load without problems than any of the other Shopsmith motors. I believe this is due to the larger and longer rotor and heavier coil wire in the windings. Two of my Shopsmiths now have this motor installed that I made reversible which was the easiest ones I have done.
paulsgreenbarn
thanks Bill for all the information.I love the looks of those old green and brown machines.I'm also partial to Antique tools in general.I have a build option for my furniture where i use Antique Hand tools for the entire build process once the materials are roguhed out using power tools.I've built a half dozen dining tableand bench sets that way so far.
do you have equipment posted on *bay?
i remember seeing a reversable power unit there.
