Speed Control
kaynyne
Speed Control
Post by kaynyne »
I took my Shopsmith Mark V (1983) apart to change the sheave and bearing. When I got it, it was almost seized up completely. My problem is, when I put it back together, how do I synchronize the speed controller with the speed of the headstock?
I haven't got my sheave yet and ,at my age, I forgot if it was on slow or high. Is there a rule of thumb to putting it back together? I took the speed controller apart and have it all cleaned and ready to put back together as soon as I get the part.
Thanks for anything that you can suggest. Kaynyne
ChrisNeilan
Post by ChrisNeilan »
Fear not, a rather simple procedure. There is a link in the "sticky" on this forum that tells you how to do it. I believe it's referred to the high speed adjustment. I'm sure someone will post the link...
Regardless of whether a 'high speed adjustment' is made, the speed control is adjusted to the high speed stop just before attaching the ring(set to fast) and control knob.
The control needs to be set to fast to install the motor belt(next).
The high speed adjustment can be done at any time. IIWM, I would not do that until it is completely reassembled.
beeg
Post by beeg »
Here's a how to speed adj.
[ATTACH]24072[/ATTACH]
how to do a high speed adjustment.PDF
(382.25 KiB) Downloaded 363 times
kaynyne
Post by kaynyne »
Thanks guys I hope this helps when it's time to put back together. Thanks again for the info. Kaynyne
Also, when Shopsmith sends the parts you have ordered, they will include an instruction sheet in the package.
kaynyne
Post by kaynyne »
Thanks for all the help. I'm sure I can handle it. I know the people at Shopsmith are great to work with, but I didn't realize that once I bought a Shopsmith that I joined a family of great people, too. Thanks again for all the help, and I know not to be afraid to ask for help again. Thanks for everything, Kaynyne
