End-grain planing
davebodner
End-grain planing
Several years ago I made an end-grain maple cutting board that's about 2" thick. It's now warped a bit so it rocks slightly on the counter. Can I use the Pro Planer to flatten it out, maybe in several passes of very shallow cuts? Or is that a dumb idea?
- BuckeyeDennis
I haven't planed end grain with my Pro Planer, but I'd expect that to work OK.
The wobble could be a problem though, unless you either flatten it first or use a planer sled.
I tried this sled technique for the first time a couple weeks ago, and got perfectly flat surfaces in one pass through my Pro Planer. I used a leftover piece of melamine-coated particle-board shelf for the sled, and it worked great.
This last weekend, I tried the same sled technique to prep a chain-sawed half log for a bowl blank. It was way too tall for the Pro Planer, so I used my new-to-me rotary planer (like a Wagner Safe-T-Planer) on the SS in drill press mode. I just slid the melamine "sled" around on the SS table and made multiple passes. First I mounted the flat side of the half-log to the sled, and planed a flat strip on top, about 4" wide. Then I flipped the log over and re-mounted it on the sled, to plane the wide side flat (to prep it for bandsawing the blank). That latter step was something of an "acid test", but it worked like a charm. I've found the sled, tape, and hot-glue method to be easy, secure, and stable.
- terrydowning
I have doubts that it will work. I wood think that the rollers wood flatten out the warp while it's being planed. But once out it will go back to the warped shape.
paulsgreenbarn
Hand plane(low angle plane) the high corners on the bottom and forget about running through the planer.
If the top side is rough, use a sander.
- rcplaneguy
davebodner wrote:Several years ago I made an end-grain maple cutting board that's about 2" thick. It's now warped a bit so it rocks slightly on the counter. Can I use the Pro Planer to flatten it out, maybe in several passes of very shallow cuts? Or is that a dumb idea?
http://youtu.be/QJ2LSj4RhAs
davebodner
- stephen_a._draper
I recommend using a portable belt sander or the Shopsmith belt sander.
Shopsmith Mark 4, Mark 7, Mark 5 shorty, planer, bandsaw, jointer, belt sander. Grizzly central dust collection 4" PVC trunk. Shopsmith Routing System stand-alone overhead pin router.
Stephen A. Draper
Author of Mark 4/7/520™ Self-Study Course ©2025
Stephen A. Draper
gr8mesquite
