Indexing wheel
Indexing wheel
I just found a company "Iron fire" http://www.ironfirellc.com
Who makes Indexing wheels, there "C" wheel has a 1-1/4" center.
It could be easly be used on the shopsmith.
there price is $24.99
Good price, It cant hurt to take a look.
Im buying one!
talk to you latter.
C.A.G.
Im buying one!
talk to you latter.
C.A.G.
- horologist
Curtis,
Let us know how it works out. I have concerns that a plastic wheel may not be too durable. But as you said they aren’t too expensive.
In a pinch there are a wide range of alternatives. I know a clockmaker who made over 30 clock movements with large home made indexing wheels made from plywood.
curtis wrote:I just found a company "Iron fire" www.ironfirellc.com
It could be easily be used on the Shopsmith.
I'm buying one!
talk to you latter.
C.A.G.
The hole size you want, I think, needs to match the whole in your lathe chuck. Any chuck that mounts on the Shopsmith will have an adapter that converts from a 5/8" female to some larger male that then screws into the chuck. In order to use the indexer, you separate the adapter from the chuck, insert the indexer and put everything back together. They sell versions for almost every standard chuck and for $5 more then will make one custom for you.
Paul Cohen
Beaverton, OR
Beaverton, OR
Hello guys
I have to go to church in a few min. So this will be short.
If you look at your shopsmith book, thay show how to make an indexing system for your shopsmith. thay connect the indexing wheel to the back side of the motor and add a locking pin to the motor/head stock.
the perpose of the indexing is so that you can flute or mortice a spindle (or even rope a spindle) by useing an indexing wheel, you can lock a spindle in what ever possision you may need.
You can do some pretty neat stuff with it!
Gota go.
have a good day.
C.A.G.
Gota go.
have a good day.
C.A.G.
- a1gutterman
Chuck, I remembered the same thing, but I thought it had something to do with the lathe or maybe cutting the wedges for glue-ups to use the ring-master with. I did a quick look this morning, but did not figure out which Sawdust Session it was. It doesn't help that I can not view the recorded versions.
Tim
Ed is correct - #8. Nick was milling flutes.a1gutterman wrote:Chuck, I remembered the same thing, but I thought it had something to do with the lathe or maybe cutting the wedges for glue-ups to use the ring-master with. I did a quick look this morning, but did not figure out which Sawdust Session it was. It doesn't help that I can not view the recorded versions.
